strange whine sound when shifting gears
Old 12-04-2014 | 10:29 AM
mattcl-s's Avatar
can't think of what it could possibly be....when I push in the clutch it makes a whine sound not really sure if the cold is causing it, but its been cold for a while never did it before. I looked on here to see if anyone else experienced and no luck, thoughts?
Old 12-08-2014 | 07:06 AM
mattcl-s's Avatar
found out the pulley for the power stearing pump was making some noise and lower on power stearing fluid but didn't make any noise when I eas turning...the pulley sounded bad though
Old 12-08-2014 | 07:13 AM
if noise is only present when you CLUTCH in.
its the throwout bearing.
Old 12-08-2014 | 09:14 AM
mattcl-s's Avatar
it only made the sound when I was accelerating...my power stearing fluid was down when I added some it went away. before that the pulley was making a strange grinding like sound
justnspace (12-08-2014)
Old 12-08-2014 | 09:16 AM
oh okay, glad you found your culprit!
Old 12-08-2014 | 09:19 AM
mattcl-s's Avatar
yeah me too! just need probably need to replace the pump or the line that's leaking
Old 12-09-2014 | 05:56 PM
fourtrax's Avatar
it's a common issue the suction line gets hard and starts leaking. just replace the following, and it would be a good idea to flush (replace) the fluid with new.
  • Part Number: 53731-S3M-A00
  • Part: TUBE, SUCTION
mattcl-s (12-10-2014)
Old 12-24-2014 | 11:33 AM
mattcl-s's Avatar
yup its the power steering pressure line 300$ parts n labor
02-25-2020 09:57 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
Iain MacLeod
09-17-2015 01:01 PM
nash3222
09-10-2015 09:46 PM
Quick Reply: strange whine sound when shifting gears
