Sticky gas pedel..?
Old 12-11-2005 | 02:20 PM
spicyhands's Avatar
Sticky gas pedel..?
At stop and go driving, everytime i push on the pedel it feels like it getstuck for a sec. I can realy never ease on it with out it jerking on me, its not smooth.
Can i do something about this? Thanks
I searched but could pin point it out
Old 12-11-2005 | 05:28 PM
Pure Adrenaline's Avatar
Dragging knees in
Probably the throttle body plate gumming up.
Best way to check to see if it's indeed the plate -- pop the hood and locate the throttle body (there are two; it's the one closer to the engine).
Pull back on the plate control mechanism by hand and see if you can feel it getting sticky/stuck. If that's the problem, then you can do one of two things --
1. Do it the proper way and take off the throttle body assembly to thoroughly clean it. This will take some time, some tools, and involves leaking coolant.
2. If you don't want to do that, then I suppose you could just take off the intake sleeve to the throttle body and run the engine while spraying some carb cleaner in there.
I would personally recommend route no.1, IF it's the plate gumming up and getting sticky.
Old 12-11-2005 | 07:07 PM
o1s's Avatar
o1s
/\/\--- what he said.
Old 12-11-2005 | 07:51 PM
NiteQwill's Avatar
Adventurist.
Clean your TB or apply graphite to your TB line. Do #1 1st like Pure Adrenaline said.
Old 12-11-2005 | 08:04 PM
anothercls's Avatar
This will randomly happen to me in the cold or after a couple days of not driving. I have never worried about it enough to consider fixing it.
Old 12-11-2005 | 08:15 PM
1upacura's Avatar
It may sound stupid but check to see if you cruise control is still on, every time mine does that it's the cruise control. Otherwise it's the throttle body.
Old 12-12-2005 | 12:57 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Definitely the TB.. had the same problem on a Camry.
Old 12-12-2005 | 12:05 PM
djarovsky's Avatar
Get a hold of a copy of TSB 04-035 (Fuel System- Accelerator Pedal is Hard to Press) from the dealer.
It addresses the common problem you stated by replacing the throttle body with a new updated part to fix this issue. The TSB states that it is related to contamination from high humidity and salt.....if I remember correctly.
Since it looks like you are from FL, it would apply to you. If you are still under warranty = free. Not under warranty = maybe free via goodwill. Work with your dealer.
Hope this helps!
Old 12-13-2005 | 05:19 PM
spicyhands's Avatar
Its not the cruise control.
I dont think the TB is dirty cause i cleaned it pretty good when i installed the ThermoB spacers. Thats was about 3 months ago
Should i try the graphite?
I'm outta warranty, so i would have to buy a new TB? How much is that?
xsilverhawkx
10-05-2015 11:00 AM
MilanoRedDashR
10-02-2015 10:49 AM
Skirmich
10-01-2015 12:59 PM
San Yasin
09-29-2015 10:52 AM
Quick Reply: Sticky gas pedel..?
