Steering wheel vibtrating
I just got my new rims put on 2 days ago, and I have been noticing that when I'm going 50ish my steering wheel starts to vibrate and go crazy. I didn't have any problems before with the stock tires and rims. I have to wait until Monday when they are open. Can someone tell me what is going on? Its really starting to piss me off
Re: Steering wheel vibtrating
Re: Re: Steering wheel vibtrating
Originally posted by Wires
Sounds like they aren't properly balanced. If the tire guy did a shitty job balancing the rubber, then you'll get that.
And....
If the wheels weren’t torqued properly and/or have run-out, you will get the problem even if the wheels and tires are perfectly balanced. (I know, 'cause it happened to me...)
http://www.acura-cl.com/forums/showt...ghlight=torque
Re: Re: Re: Steering wheel vibtrating
Originally posted by EricL
...If the wheels weren’t torqued properly and/or have run-out, you will get the problem even if the wheels and tires are perfectly balanced...
Re: Re: Re: Re: Steering wheel vibtrating
Well thanks for the info. Hopefully they will eliminate this problem when I take it in tomrrow
I'm wonderin the same thing.
Originally posted by Rod
Run-out?? What exactly do you mean?
Same Thing happened to my car as well when I put my rims on. Wish I had known sooner as I spent way too much money on repeated balances which did nothing for my high speed wheel shake.
hmmmmmmmmmmm
i always thought the slight harmonic vibration was from going to fast on bad freeway surfaces???
should i just go to my dealership and ask them to do an alignment
The I definatley noticed a difference in road feel with low profile tires, but I got used to that after a while. Another thing about my wheel shake is that it would occurr randomly. Some days it would be violent and then nothing for a few more days (same 40 miles freeways drive each day)
Originally posted by MtBikR
...Another thing about my wheel shake is that it would occurr randomly. Some days it would be violent and then nothing for a few more days...
When tires or wheels are not perfectly centered, they tend to bob up and down. The term "run-out" can be used for lateral movement (e.g brake rotors, bearings == lateral run-out) AND/OR for radial run-out for rotation that is not perfectly circular (think of a tire with a huge flat spot) or a tire/wheel that isn’t centered (think of a cam lobe).
The reason I left the link (to augment) the brief description about my little "unhappy" rotate and balance session, was to point out that most shops are not going to take the time to do a "weenie-like" job (they are not going to treat the car like it is their own).
The Acura seems to really be sensitive to "run-out" issues and just having the nuts tightened by a moron was enough to cause the steering wheel to go nuts at 50-60 MPH.
The wheels and tires were first rechecked for balance (and were OK), but I had them do the balance at the highest speed possible and I don't think that was the problem.
When I got together with one of the "old-timers" that had been out for lunch, we noticed that the back of the wheel nuts had a wear pattern that looked like they had NOT been seated correctly. (That's why it can help to put a little dab of some lithium grease [or whatever] and hand tighten the wheels nuts in a "star" pattern to make sure that the wheel takes a "perfect" set (the tiny film of grease helps to allow the 5 wheel nuts to be perfectly centered in their holes). THE backs of my nuts (for the SSR wheels) have a taper and can end up getting "cocked" out of place. By slowly winding the nuts in by hand, it insures that some pit-crew-wannabe doesn't offset the wheel center and end up causing the wheels to bob up and down like an apple in a water barrel!
So, if anyone thinks some of the stories about "using star patterns" for torquing, or hand tightening first, or slowly increasing the torque is BS, I can assure you that it can make the difference between a “shake-mobile” and a car that is dead steady at 100MPH (zero vibration)...
BTW, it is also possible to get out of round wheels or wheels with run-out and it is also possible to get oversized tires installed on an undersized rim (this can make for terrible radial run-out problems).
YMMV
rockyboy
08-04-2024 10:35 AM
EvilVirus
12-10-2015 07:38 PM
