SRS light stuck on
SRS light stuck on
SRS light. Just above the F for full icon on our fuel indicator circle.
Supplemental Restraint System Indicator.
Owners manual: This indicator lights when you turn the ignition switch ON (II). If it comes on at any other time, it indicates a potential problem with your front airbags. This light will also alert you to a potential problem with your side airbags, passenger's side airbag automatic cutoff system or automatic seat belt tensioners. For complete information, see page 45.
Page 45:
If the SRS does not come on after you turn the ignition on.
If the light stays on after the engine starts
If the light comes on or flashes off and on while you drive.
If you see any of these indications, your front or side airbags may not deploy, your passengers side airbag automatic cutoff system may not work properly, or your seat belt tensioners may not work when you need them.
Go to your Acura dealer as soon as possible with your lifes savings bank account.
-end owners manual.
Okay what probably brought this on my 2001 CLS is, i replaced the power window regulator on the drivers side. The little motor thing and swivel arm that raises and lowers the window. Did I bump or alter something near the airbags to cause this light?
What is solution?
Page 45:
-end owners manual.
What is solution?
Originally Posted by fuzzy02CLS
This may be your problem, from the FAQ....
https://acurazine.com/forums/showthread.php?t=179416
sayfulhaqq You can also take it to the dealership and they can check the code, mine came on and it was a faulty sensor, they replaced everything for free because of the warranty
Thanks both of you for the info. Will post results.
More advice needed!
Dealer service says that true, while the SRS is extended warranty to 150K, the SRS lighting up can be for 27 different reasons, thus 27 different codes can come up. He continues, "While most of them are covered, all are not."
I'm thinking i get reassurances that if the code they come up with is not covered, they button the car back up and give it back with no charge. None of this "we can't legally let it go, its not safe" stuff. "and that will be $650 to fix the code we came up with".
fuzzy or anyone can you direct me to a link that tells what all the different codes related to SRS light mean?
New to this
But anyway's my srs light cam on after i unplugged my guage cluster to change the lights and now it's stuck on i brought it to the acura dealer in Tampa and they only charged me $50 bucks
Originally Posted by NighthawkBlue
More advice needed!
Try this:
When you have a passenger , have the person lean forward close to the dash and see if the side airbag light lights up. My SRS light came on after I was cleaning the car and moving the seat in various positions.
Finally when the dealership ran my code:
Code presented 15-3 Faulty OPDS Sensor
They replaced the sensor and unit , cleared the code all under warranty.
Parts (2003 acura cl-p)
(Quantity) (FP-Number) Description
1 - 81127-S3M-A71 Pad , R. Fr.
1 - 81334-S3M-a74 OPDS Unit
3 - 91566-SP0-003 clip, back cover
Hope this helps!
Originally Posted by StypeCL02
New to this
Originally Posted by foreveraflboy
I would be currious to know how you reset your light. The few post that I remember where all "getto" fixes on way to reset it.
https://acurazine.com/forums/ramblings-12/what-world-happened-gas-prices-while-i-gone-195351/
Yes. Salvage cars are not covered by any recall or warranty extension
No on warranty extensions, thats why they wont give us a new tranny but will only do the oil jet kit since thats a recall. the tranny is the warranty extension. but if they determine during the oil jet kit install that your tranny is bad from the bad 2nd gear, they will give you a new tranny.
Yes, I corrected a mod. What do I get?
![hide](https://acurazine.com/forums/images/smilies/hide.gif)
666 Speed
1 Post
My SRS light came on. Had the dealer fix it under warranty along with the non-retracting drivers side seat belt, It was a faulty OPDS unit too. They replaced it and 5 days later it came back on. dropping it off again today for them to replace it with an updated one.
Hopefully, this helps clear things up.
I just got off the phone with Acura Client Services and this is what I was told...
If, the car has a branded title (salvaged) the vehicle is ineligible for any extended warranties....like the 2nd Gen transmission issues, etc.
The OPDS Sensor, which is often the faulty part, is an item covered by Acura's warranty and wouldn't be replaced by the dealer for any CL owner with a branded title.
However, if it is determined that the faulty part is not the OPDS Sensor and rather with the mechanical belt, female belt buckle, or physical seat belt.
That is an item covered by all Acura dealerships under the general lifetime warranty of the seatbelt.
So, you need to find out what is "tripping" your SRS sensor and determine exactly what is the faulty part.
In the case for me...it is the female belt buckle and that will be replaced under the lifetime warranty of the seatbelt.
NICE!!! Just saved myself 90 bucks!
![Boogie](https://acurazine.com/forums/images/smilies/boogie.gif)
I just got mine back this morning from Acura of Serramonte.
Same issue on the female passenger belt buckle and everything is cool now.
Glad you were able to get it fixed so easily also.
The TSX is really stiff in the steering column...I don't like it.
jamestheunderdog
07-19-2016 07:58 PM
mugen_kid
11-13-2015 10:38 PM
