SRS Light just came on??? Help!
Jared
I noticed that my SRS light just came on this weekend. I have a 2001 CLS with Auto. I have about 62400 miles on the car? Any hidden hidden warranties on this item? Also, does anyone know how to check to see if a CL has an extended warranty through Acura after 50,000 miles? Thanks.
![Hang](https://acurazine.com/forums/images/smilies/hang.gif)
Adult Supervision
reset it. do a search on it and you will find instructions. pm if you can't find them. if it comes on again, you may have a real issue.
Beware of leakage
Here is the easy fix, to reset the light. If it keeps coming back on, you have a bigger issue, like the sensor going bad.
Found this in another thread.
Originally Posted by G-UNIT
Paperclip fix....
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
Back to Four Doors
Originally Posted by Titand19
i had the prob, it was a bad seatbelt buckle.
Regions Leader
Regions Leader
My SRS light came on. I took it straight to the dealer. It ended up being the computer. At least thats what they told me. Im not sure if its warrantied with more than 50k though.
Beware of leakage
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Anyway, the paperclip fix, has worked for me x 2. Just be careful, I accidentally blew my fuel pump fuse while doing it the second time. Simple repalcement of fuse and all was fine again.
call dealer and see if it's still under warranty,,,some safety stuff has extendeded warranty. My passenger seat belt sensor went bad at around 45k miles,, no problems sence.
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
