SRS light is on
Old Aug 24, 2005 | 09:46 AM
russianDude's Avatar
SRS light is on
just turned on for no reason. I called acura customer care and opened a case. If its something expensive, I will do everything I can to avoid paying out of the pocket. I told them to review my long history of warranty/after warranty problems I have had with my car. I told them I am very concerned with the reliability of this car, which supposed to be luxary. will see what happens....
Old Aug 24, 2005 | 09:51 AM
whats funny is that acura customer care said they looked through their database of known problems, and SRS light turing ON was not reported.
I've seen at least dozzens of posts on CL/TL forums people haing the same exact problem of SRS light just turing on out of blue.... I think there is also a TSB on this... but sure enough they try to hide all this...
Old Aug 24, 2005 | 09:55 AM
Dead-Fox's Avatar
Yup- mine has also been on for a couple months now- I recall reading that it will cost us $$ to fix it because of a 'defective module' under the passenger seat that isn't covered under the warranty(?) so I have ignored it. please let me know what you find out!
Old Aug 24, 2005 | 10:01 AM
RaviNJCLs's Avatar
Mine went off twice, but both times they took care of it for free. One of the times was over the 50K mark.
Old Aug 24, 2005 | 10:04 AM
It could be number of reasons: deffective sensor and/or defective moduls....Someone I know was quoted $600 to replace SRS module...
If its anything over $100 and dealer can not give me one time favor, I am raising hell to Acura Devision of American Honda. I am getting fed up with all the problems...
Old Aug 24, 2005 | 10:06 AM
I hope it was not like "we don't really know what the problem is, so we just going to reset your light and hope it will never come back on again"
Old Aug 24, 2005 | 10:33 AM
msong1's Avatar
i got mine fixed for 95 bucks at acura dealership
and then came back on 3 weeks later
1st time they said some sensor crap my diverside airbag was deactivatedand they put the plug back in
the next time they said it was my blue tooth tecjnolgy from my phone that set it off
which is crap they said it interfied with the sensor regardless
they hook up to a computer and just reset the light
shouldnt be more than $95
from an acrua dealership in baltimore
Old Aug 24, 2005 | 10:37 AM
thats the diagnostic charge I was quoted, plus all the parts and labor to get it fixed.
I dont like the idea of simply reseting the light, the chances are it will come back on... and then you have to waste your time again, and do they expect you to pay $100 diagnostic charge again??
Old Aug 24, 2005 | 02:46 PM
TypeS300's Avatar
Mine had only 2 doors
laptops,headrest monitors and certain other electronics will set it off.
Try disconnecting the battery that will reset it and if it comes back then you might have to bring it in
Old Aug 24, 2005 | 02:51 PM
Standout's Avatar
National Champs GO GATORS
Yeah, mine came on too, i've just ignored it and kept driving, however it does aggrevate me. Mine came on after my door lock broke and in trying to take the door pannel off with the door closed, the computer board where you roll the windows down cracked. I fixed that, then the light came on. Its been a real joy!
Old Aug 24, 2005 | 03:00 PM
lilnas1's Avatar
I am so annoyed by it . One day I am going to take out the panel and pull the light bulb out. Hey, as long as my seat belt works...I am good
Old Aug 24, 2005 | 03:56 PM
6MTpromises's Avatar
Relax!
^ but your airbags won't
Old Aug 24, 2005 | 04:58 PM
CL'er's Avatar
Thats not true, i got into a head on with my SRS light on and both of the airbags went off no problem.
Still hurtin from that drunk fuck.
Old Aug 24, 2005 | 06:10 PM
I think it depends how bad the problem is. What sucks is that light comes on in case of a serious or a minor problem, so until you have it checked out you will never know....
Old Aug 25, 2005 | 03:35 PM
just got back from the dealer, turned out that its a bad seat belt buckle. Its all covered under seat-bealt life time warranty, so I would not need to pay for anything. I did not pay diagnostic charge, but they made me buy a battery for $140
I guess I am lucky that it turned out to be this way...
Old Aug 26, 2005 | 07:18 PM
Johnny Rad's Avatar
How about this one...
Dealer extinguished my SRS light by replacing a defective seat belt buckle. "Buckle tested bad." I forget the explanation, but probably wasn't making a circuit or something.
Old Aug 27, 2005 | 12:09 AM
Chopsie's Avatar
Beware of leakage
Jesus, I bought an "Acura" battery once, and it was only $75
Glad your bags are in proper working order again though
Old Aug 27, 2005 | 01:17 AM
yeah, I belive you can get the part for about $80, and they probably charge $60 to install it. I could have installed it myself in 5 minutes, I just did not feel like arguing and wasting my time. They told me that battery is low and it could be causing SRS problems and that they can't really guarantee their diagnostics without a good battery. So I was like "ok, fuk it, just do whatever to fix my light".
Old Aug 27, 2005 | 04:08 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Sounds like your dealer took you for a ride. I hate car dealerships. You should have said they could take their Acura battery and stick it... sideways. If they wanted you to have a new battery, you'd be glad to go grab a cheap one from the local Autozone.
But for the record, unless you simply have a shorted out SRS light, the airbags WILL NOT DEPLOY if the light is on.
Old Aug 31, 2005 | 01:51 PM
kensukikatayo's Avatar
Turbo + Sound = Hey-pee
Mine went off around 56k so I brought it in and they fixed it for free because apparently I had an extended warranty that the first owner bought and it just turned out to be a sensor in the passenger side seat belt? They just cleared it and it's fine now.
Old Aug 31, 2005 | 06:42 PM
quicksilver10101's Avatar
honestly if you wear a seatbelt you dont need airbags anyway....i have totaled 2 cars now both head on collisions and all the airbag did was burn my arm both times....wear your seatbelt and you dont need airbags...f@uck the srs light and the stealership
Old Aug 31, 2005 | 06:44 PM
I've been in a few accidents one of which i span out on the freeway and span at least 3 360's at 80 mph and slammed into the center divider and the airbags still never came out. It's just annoying seeing a red light on ur dash...
Old Aug 31, 2005 | 10:27 PM
i remeber reading about a way to jump 2 wires togetehr and you can turn the light off by yourslef...does any one know how to do this b/c mine comes on about every few months and ive always been lucky enough to bring it to the dealer for sumthin else and they shut it off but i dont feel like payin them $95 to shut it off
Old Sep 1, 2005 | 12:50 AM
Yea, do a search, i found it on the forums before but I don't have the link. There's a DIY on it with pictures
Old Sep 1, 2005 | 01:41 PM
anyone have a link to that?
Old Sep 1, 2005 | 01:45 PM
https://acurazine.com/forums/showthr...ht=Light+Reset
Old Sep 9, 2005 | 08:34 AM
just got back from the dealer, they replaced a driver's seat belt buckle and the SRS light problem is now fixed.
It was all covered under seat-belt life time warranty.
I hope next "light" won't come on for a long time
Old Sep 9, 2005 | 01:10 PM
SanDogDewey's Avatar
Mine was fixed under warranty by replacing a seat belt.
Old May 9, 2006 | 09:38 AM
CQ7String's Avatar
metalguitarist.org
That's exactly what I did.
Old Jun 2, 2006 | 10:02 PM
flint's Avatar
hate to bring this back from the dead but does anyone have new info on this? Been searching all over including FAQ's. Mine SRS light just came on.
Old Jun 2, 2006 | 10:09 PM
LacViet's Avatar
291hp & 245 tq @ 3.5psi
follow this link to reset the SRS if it's on due to you disconnected the battery or messing up with the electrical; otherwise, bring to the dealer to check out for safety reason.
http://www.geocities.com/myintegra96/srs.html
Old Jun 2, 2006 | 10:18 PM
flint's Avatar
Nevermind. i found what i needed. Patience is always a good thing...
Old Jun 3, 2006 | 11:37 AM
d98clturbo's Avatar
Old Timer
those instructions are GREAT i fixed the proplem in like 40 seconds
THANKS
Old Jun 3, 2006 | 02:40 PM
TOPHER33884's Avatar
All CL's have an extended warranty of 150,000 miles for the SRS light. Mine has 132,000, and just got the passenger seatbelt replaced for free.......and no more light. Although I did have to pay 348 dollars for a new drivers side window modulator! LOL, so they fucked me in another way!
Old Jun 3, 2006 | 08:13 PM
mefromuic's Avatar
I just got my CL back from the dealer today to fix heating coils in the passenger seats. I noticed the SRS light on when i drove away. Had to take it back for them to reset it.
I've been told this before. Its some sort of recall which turned into an extended warranty. Theres a sensor under that passenger seat that disables the passenger airbags thus making the SRS light come on when it senses something under 30 pounds. Its a safety feature incase its an infant/child of which they are assuming the airbag would be of no use and would actually hurt the infant/child.
They gave me a 06 TSX as a loaner. I definitely noticed the lack of power compared to my CL-S. But I do like the new technologies. Like the instantaneous mpg calculator, etc
Old Jun 3, 2006 | 08:39 PM
Hey guy, check the forum, I found some info that my freind at Crown Acura in Clearwater sent me awile ago........the MODS "sticky'd" it. It should save alot of CL'ers some time and money!
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
