SRS light on?
i like orange juice
do a search for the thread that says how to clear it..if it comes back on..then youve got problems....most people have it come on for no reason.....
thanks for the help,i gotta use the search function more,i just keep forgetting.
Do you have stuff (anything) on the passengers seat ??
If so, remove it. If not, a sensor might have gone bad (there's a couple of threads here about that).
Mine goes on all the time now, first time the dealer said its a MIsc Code for nothing, Electrical Interference. Crap if you ask me, but i have to reset it all the time
1- look underneath dash, near fusebox, for a 2-wire yellow plug, disconnect it and pull it down so you can work with it.
2- turn ignition OFF
3- jumper the 2 wires together (cut paperclip in half and straighten, insert one end of both halves into back end of plug where each wire goes in, touch them together and hold)
4- turn ignition ON (SRS light will turn on for 6 seconds, then turn off)
5- within 4 seconds of SRS light turning off, unjumper the 2 wires (SRS light will turn back ON)
6- within 4 seconds of SRS light turning on, jumper the 2 wires (SRS light will turn back OFF)
7- within 4 seconds of SRS light turning off, unjumper the 2 wires (SRS light will blink ON and OFF, indicating SRS function is reset)
See ya SRS light...
When you're done don't forget to plug the connector back in.
See ya SRS light...
Originally posted by RaviNJCLs
Not as complicated as the other replies. I took it to Acura, they changed the sensor for free and the light went off.
Try that.
Try that.
Since mine is not, I'll stick to the *free* paper clip.
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
