srs indicator light
Old Oct 15, 2001 | 03:12 PM
goldn1's Avatar
Member
srs indicator light
friday my SRS indicator light came on (again)
the first time was a couple of weeks ago and the dealer couldn't find anything wrong and just reset the computer.
this time it gave the exact same computer code and they decided to replace the doohicky that is failing and tripping the code.
not sure what the doohicky was called, but I'll update when I see them tomorrow. they are fedexing a new one in.
just a little fyi - if your SRS indicator light goes on - call the dealer ASAP - it indicates that the airbag system is totally disabled because of an error.
anybody else have any problems with their airbags?
Old Oct 15, 2001 | 03:44 PM
CO-CL-S's Avatar
Re: srs indicator light
I think your dealer is panicking you for no reason. I had an SRS light come on, and it was a code indicating one of the seat belt buckle sensors was bad.
Old Oct 15, 2001 | 04:07 PM
mantis23's Avatar
Moderator Alumnus
When my SRS indicator light came on, I went in to the dealer and they said I needed a new SRS detector unit for my passenger side seat.
Sounds like the same thing you need goldn1.
They did a horrible job of putting it in. Stuffing was visible from a profile side view of the passenger seat. Just this weekend I conditioned the leather and found a screw wedged down in the velvet part of the seat. I'm assuming it was a screw they left out during the SRS detector unit install.
Even to this day, if someone leans on the seat in a bad position, the light will come on briefly until they readjust their body.
So now I'm always telling passengers
"Hey, don't lean too much on the seat because the SRS light will come on."
They give me a comatose stare and ignore me. I love my car.
my 2 cents
Old Oct 15, 2001 | 04:13 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Have the SRS when the front passenger lean toward the window is a normal behavior. Only side air bag is shut off.....
Old Oct 15, 2001 | 05:09 PM
bl^5's Avatar
Got da Internet Goin Nutz
I had the same problem with my SRS light. The doohickey in the passenger seat actually has a service bulletin out to be replaced. The dealer should replace it for you.
The dealer did a bad job replacing mine too. It must be difficult to get the passenger seat backing back on correctly.
Old Oct 15, 2001 | 05:20 PM
mantis23's Avatar
Moderator Alumnus
At least now I don't feel singled out about the bad doohickey install.
Welcome aboard, bl^5
Old Oct 17, 2001 | 02:36 PM
DreamU's Avatar
My doohickey was called OPDS - Occupant Position Detection Sensor. First time they just reset the system. The second time they replaced the OPDS. The Service guy claims that whenever the SRS light comes on the airbags are disabled.
Old Oct 17, 2001 | 02:59 PM
wayneg's Avatar
The "doohickey" or OPDS is not really hard to put in- the tech just has to be careful The "side- airbag" light is supposed to come on to indicate that the passenger is leaning in the path of the side airbag- the occupant position sensor detects this and the control unit will then diable the side airbag. When the red SRS light comes on, that means the controller has seen a problem in the airbag or seatbelt system and has turned off the complete airbag system. That means that if you have an accident when that light is on, the airbags won't deploy. You should have the red SRS checked as soon as possible.
Old Oct 17, 2001 | 04:59 PM
goldn1's Avatar
Member
that was my doohickey too!
picking up my baby tonight, hopefully they did a good job with the replacement...
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
mugen_kid
Nov 13, 2015 10:38 PM
Phambam12
Sep 6, 2015 06:57 PM
