Squeaky tob
Old Mar 4, 2012 | 05:57 PM
Jmoney6's Avatar
Squeaky tob
When we did my clutch we didn't put enough greese on the tob and it's now squeeking at idle. Can I remove the clutch fork and regressed it with out having to pull the entire tranny again?
Old Mar 4, 2012 | 06:11 PM
civicdrivr's Avatar
Nope.
Old Mar 4, 2012 | 06:25 PM
Jmoney6's Avatar
Entire tranny has to come out?
Old Mar 4, 2012 | 06:30 PM
civicdrivr's Avatar
The throw out bearing clips onto the back of the clutch fork. Even if you could get the fork out, youd be hard pressef to get it back in properly.
Old Mar 4, 2012 | 06:45 PM
Jmoney6's Avatar
Is there any way to get grease in there with out getting anything on the disk or basket?
Old Mar 4, 2012 | 07:07 PM
civicdrivr's Avatar
Its very tight. I wouldnt try it.
Why is the bearing squeaking? Did you reuse the old one?
Old Mar 4, 2012 | 07:12 PM
StreetKA's Avatar
try spay some liquid wrench or whatever it takes but not much and u must be precise...because you can spay on the clutch and ruin it... that will work for a bit but you must grease it anyway... maybe removing radiator fans could give you more room to do it... good luck
Old Mar 4, 2012 | 07:15 PM
Jmoney6's Avatar
I used a new tob the kit just came with crappy grease I guess
Old Oct 4, 2012 | 10:05 AM
TrixR4Kidz's Avatar
does it creak/ squeak when you engage/ disengage the clutch? I had this problem and traced the sound back to the TOB but turned out it was only the pedal. put WD-40 in the clutch master and it went away. worth a shot ya know.
grantjp
Apr 19, 2012 09:15 PM
<syphers>
May 31, 2008 07:03 PM
<syphers>
Aug 5, 2007 04:02 PM
Sleep_DEPRIVED_Sleeper
1G CL DIY & FAQ
22
Jun 8, 2007 09:35 AM
03typeS6spd
Jun 2, 2004 08:07 PM
