Springs will be installed...
Ambidextrous Masturbator
... on Friday at 9 AM. I'm getting H&R Sports. I can't wait. I'll make sure to post pics of before and after with measurements.
My car is going to look and handle great!
Originally posted by Type S Smokes Weed:
<STRONG>yes it is. you're gona be taking every corner at like 50 now so watch out
</STRONG>
</STRONG>
Faster... I already take corners that fast.
I just need stickier tires.
I ordered my H&R sports springs (stage 2) too. Just waiting for them to get in and have them installed. But now I'm wondering if I should just go with NEX coilovers when it's going to cost me about the same for springs and shocks. Speaking of which, after getting my springs installed on the stock springs, how long should i wait before getting new shocks? And how would you compare ride quality between H&R and Eibachs? I'm getting H&R for sure, bu just out of curiosity. I'm hearing different things. Thanks.
Oh yeah, my mechanic said that by installing the Koni yellows alone will lower the car about an inch since it has an adjustable perch. Is this true? So, if he's right, then with Koni yellows and H&R sports, the total drop would be 2.75" ? Is that correct?
Originally posted by GooWakJai:
<STRONG>Oh yeah, my mechanic said that by installing the Koni yellows alone will lower the car about an inch since it has an adjustable perch. Is this true? So, if he's right, then with Koni yellows and H&R sports, the total drop would be 2.75" ? Is that correct?</STRONG>
<STRONG>Thnks Sid. So how did you decide on H&R as opposed to the other brands? Are you getting shocks at the same time or are you holding off on those till your stock ones blow out?</STRONG>
I am holding off on shocks for now. It depends on the ride quality with the stock shocks. If it is too stiff, I may go for the shocks before the stocks blow out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
