spark plugs for nitrous
Old Feb 15, 2005 | 02:46 AM
mattg's Avatar
I currently have zex plugs and i'm contemplating changing to denso iridum.
i've had an intermittent problem w/ my car not starting on the first try (maybe once a week). i'm not sure if it's the zex plugs or the unichip that causes the problem because they were installed at roughly the same time.
anybody have any opinions on which is better?
if i do go w/ the denso would i need the IK22?
Old Feb 15, 2005 | 09:52 AM
SCTL-SS's Avatar
13.68 @ 102.56
On my car it has IK 22 and they are a great plug. As for your application I'm not sure?? Maybe IK22 or 20??
Old Feb 15, 2005 | 01:17 PM
mattg's Avatar
any other opinions?
Old Feb 15, 2005 | 03:06 PM
johntypes's Avatar
I am using 1K20 a little cooler
Old Feb 15, 2005 | 03:10 PM
mattg's Avatar
are you getting nitrous, john?
Old Feb 15, 2005 | 03:32 PM
mrsteve's Avatar
Yes I believe he is.
Matt, I had the starting problems every now and then with the UniChip also. I know other people also experienced similar problems.
I use the IK22's with my current setup and the car starts on the 1st or 2nd crank everytime, even now at 86k miles
Old Feb 15, 2005 | 04:05 PM
johntypes's Avatar
I think I am going to a 75 shot my best time is 14.10@100.70 union grove wi. I have every comptech product plus pulleys fuel pump adj. fuel reg.I do not have uni -chip or mugen cooling. What shot are you using and when do you hit NOS 1st gear or 2 gear and what RPM/
John
Old Feb 15, 2005 | 06:36 PM
mattg's Avatar
i have been running a 75 shot, and it doesn't activate until WOT. so i have to be careful and not floor it too soon or it will smoke the tires through 3rd gear.
i go out of the hole part throttle and when i feel i have enough traction i hit it. then it's time to hold on and hit the shifts.
Old Feb 15, 2005 | 07:35 PM
johntypes's Avatar
I would assume each time you go to the track it would be diffrent, what RPM would you say you hit it and what kind of tires are you running.I am running michelon pilot sports havent had them to the track got then late nov.
John
Old Feb 16, 2005 | 12:42 AM
Allout's Avatar
Blown is Best
As far as what plug I recommend, it depends if I'm lining up against you. If I am, I recommend Champion resistor plugs.
The Iridium's are a good solid plug and I don't think you can go wrong with them. What's the price difference between the plugs.
Old Feb 16, 2005 | 12:53 AM
mattg's Avatar
i can get zex for $38 shipped
and denso IK20's for $53 shipped
the zex aren't iridium, but they are designed for f/i and n2o.
Old Feb 17, 2005 | 01:21 PM
mattg's Avatar
can someone tell me which denso's to get if i want to be a heat range or 2 cooler than stock?
Old Feb 17, 2005 | 02:07 PM
mrsteve's Avatar
IK22 is 2 steps colder.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
