Spark Plug Gap-What is BEST?
Old May 3, 2003 | 07:36 AM
Juker008's Avatar
TRELOS
Looking through the CLS manual about spark plug gap, it states that for new it sould be .04" (1.1mm) . But my friend told me that in the HELMS manual it states that the gap should be 'between' .039-.043.
So my question is what is the benifit of having a smaller gap compared to one that is larger?
Juker008
Old May 3, 2003 | 07:52 AM
Zapata's Avatar
Cost Drivers!!!!
wider gap usually helps to increase burn time and thus equaling more power.
Old May 4, 2003 | 02:59 PM
Wires's Avatar
...until you reach a point where
a) Spark has trouble jumping the gap and you get miss fires (better ignition will cure that)
b) Spark get's blown out (the case with applications with boost). Then you usually have to lower the gap to ensure no misfires.
Old May 4, 2003 | 03:02 PM
Zapata's Avatar
Cost Drivers!!!!
Yes! You are correct Thanks for filling in what i left out.
Old May 4, 2003 | 09:31 PM
Juker008's Avatar
TRELOS
So would u guys say go ahead and have the gap on new plugs at .045 (manual says .040 new)?
Juker008
Old May 5, 2003 | 12:09 AM
Zapata's Avatar
Cost Drivers!!!!
Juker008
.43 would be good. Go with what the manual says. I would also check the spark plug manufacturer website.
Old May 5, 2003 | 12:15 AM
God's Avatar
God
GOD Of ACURA-CL.COM
Are the denso iridium plugs good ? If so how much are they and where would I go about getting them .
Old May 5, 2003 | 01:30 AM
Juker008's Avatar
TRELOS
www.imotorgear.com
Cheapest, not the fastest, but fee s/h.
Juker008
Old May 5, 2003 | 10:57 PM
God's Avatar
God
GOD Of ACURA-CL.COM
what kind of plugs do u recommend ?
Old May 6, 2003 | 03:34 AM
Juker008's Avatar
TRELOS
IK20
Juker008
Old Oct 24, 2014 | 11:58 AM
Xxb005txx's Avatar
Gabriel Alejandro Iser
Originally Posted by Juker008
IK20
Juker008
Noob question here. Does the NGK iridium spark plug come with a standard gap that is good for the 2nd gen tl? Or will i need to buy a gapper and adjust the spark plug gap?
Old Oct 25, 2014 | 01:46 AM
YeuEmMaiMai's Avatar
use the factory recommended plugs and DO NOT GAP them, they already come gapped. you can damage the electrode tips if you gap them. Plugs in our cars are rated for 120K miles so you should be fine. I pulled mine at 90K and they were still pristine but I changed them anyways. Did not notice any difference in how the car ran. I am now at 138K
Old Oct 25, 2014 | 08:45 AM
fsttyms1's Avatar
Yes, as stated above, do NOT try to gap them. You can carefully check that they are the correct gap but they should already be there.
Old Oct 25, 2014 | 01:35 PM
Xxb005txx's Avatar
Thanks dude^
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
