Soot in tailpipe
Old Jun 14, 2005 | 12:18 PM
NighthawkBlue's Avatar
Soot in tailpipe
Dry black soot in tailpipe okay? Causes?
Realize this is an openended question, many may have the same symtons so here goes:
2001 CLs. Bought used certified in March 2004 with 40K miles. Currently at 58K. All stock.
Dry black soot in tailpipe. I just douched it out with rubbing alchohol so as to monitor what comes out now > future. All the dry soot out, if any know how to bring the inner tailpipe back to shiny metal, let me know. Black coloring remains on about half of it.
Oil burning: None. Between 5K oil changes its all good.
Startups. Will have buddy start it up as I eyeball exaust and then give exact details. Sorry for the lame report for here and now today.
Smell: I can't tell if its too sulfery or if thats just the normal smell of startup gas.
ajtcl had some ideas on a similar problem, sugg the cat may be malfunctioning. https://acurazine.com/forums/showthr...=soot+tailpipe It does seem to reek a bit, or is that just normal?
Gas: I did run 87 the first 7K i had the car. Pinging. In an easy mechanical move my head was pulled out of my ass, I read owners manual, have used 91 since. Pinging went away within a tankful. However, I'm told the soot has nothing to do with the 87 gas.
Plugs will be checked soon.
Valve adjustment? How would one know if neccessary?
Old Jun 14, 2005 | 12:24 PM
NSXNEXT's Avatar
It's fine. Just a byproduct of burning fossil fuels.
Old Jun 14, 2005 | 12:36 PM
03 CL TypeS's Avatar
That's normal for a diesel car!
j/k
Old Jun 14, 2005 | 12:56 PM
RaviNJCLs's Avatar
It's normal. Mine needs to be cleaned too.
Old Jun 14, 2005 | 01:01 PM
fuzzy02CLS's Avatar
It's normal. Some cars have more of it then others. You can chalk it up to how rich the CLS runs. All rich running cars have alot of soot. Might also explain why a dirty IAC & TB are common on this car too.
Time For Sleeep's Avatar
That's Racist
Any of ya'll have a suggestion for cleaning? All I did was try to wipe the insides up a bit. Didn't improve much.
Old Jun 14, 2005 | 01:10 PM
ajtcl's Avatar
Peace, Love & Acura
Use SeaFoam... I did a post in 1st Gen. on how to use it. And so have others. I think mine was the most recent.
As for soot in the tailpipe, it is normal to a degree, but if you have lots of it, that could be a sign of fuel not completely burning. A rich running motor can clog your cat much faster. You may want to have your emissions checked.
Old Jun 14, 2005 | 01:37 PM
RUPNOK's Avatar
'08 TL-S
steel wool...
Old Jun 14, 2005 | 02:25 PM
Thank you everyone. Good to know it's most likely just normal fossil fuel.
I did a cold start, turned the key then ripped back and checked the exhaust. For 2-3-4 seconds it was completely clear. Then started the clear/white/grey misty fog, which seems normal, right? About 20 seconds in it went away.
ajtcl, as to the cat , is there a way to unclog it?
Old Jun 14, 2005 | 03:33 PM
That's Racist
Originally Posted by RUPNOK
steel wool...
Is still wool okay? I have aftermarket stainless steel headers. I've been using EAGLE metal polish for it, but it's just not cutting the job.
Wouldn't wool scratch?
Old Jun 14, 2005 | 05:10 PM
mrsteve's Avatar
You think it is bad on a stock car. Try it with a Comptech supercharger and exhaust!
Old Jun 14, 2005 | 06:15 PM
Smitty's Avatar
YES!!... it will scratch the shit out of your stainless... but he is prescribing that you use it on the inside of the tailpipe..
stick to your eagle one... or buy some BOM's AWAY
Old Jun 15, 2005 | 07:46 AM
RUPNOK's Avatar
'08 TL-S
yes, inside only. not for chrome trim piece. sorry if that wasn't clear...
Old Jun 15, 2005 | 10:07 AM
allmotor_2000's Avatar
Just use nail polish remove (or isopropyl alcohol).
Old Jun 15, 2005 | 11:14 AM
That's Racist
For the outside or inside?
Old Jun 15, 2005 | 11:32 AM
That's Racist
I'm a little apprehensive about using steel wool on my insides too. they're not going to leave marks?
Old Jun 15, 2005 | 12:12 PM
RUPNOK's Avatar
'08 TL-S
on the inside of the actual pipe, shouldn't. SS is harder than steel wool. the outer chromed trim piece, maybe softer and might well scratch. you could try a really fine (4-0 or 5-0) wool, would be less likely to scratch and if it did would be more satiny looking rather than coarse marks. if you're really concerned you could try a test area out of view, or just not mess w/it at all.
Just off the top of my head, has anyone tried wheel cleaner? soot is probably similar to brake dust in being inert and sticky.
Old Jun 16, 2005 | 09:20 AM
mlb585's Avatar
Regular steel wool WILL scratch stainless....Cooper wool will not.
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
DerrickW
20
Sep 27, 2015 02:45 PM
Sep 17, 2015 09:01 PM
Sep 14, 2015 10:09 PM
Sep 13, 2015 01:59 PM
