Something is up.. Need help!
Old Aug 2, 2007 | 08:56 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
Guys as you all know i had the alky installed lasr week and everything went well. Something strange happend to my car today and I want to know what it may be.
As I was driving I punched it and it just tooook off but when it hit third gear it SLOWED DOWN and the check engine light was blinking over and over. the alky was runnning so i know it wasent that. Could it be that bad TPS sensor that I h ave never replaced? The engine didnt seem to be detinating or hesitating at all. but something was and is obvoiusly not right. Can anyone help out to what it may be? I;m hoping it just the TPs that went all the way bad... PLEASE HELP
Old Aug 3, 2007 | 03:16 AM
All Mine's Avatar
I'm a Vagiterian.
Pull the code on a scanner. Sounds to me like may be spark issues. But I could be wrong.
Old Aug 3, 2007 | 07:28 AM
italiaCLs's Avatar
im going to go to autozone and pull the code. I was thinking misfire but it was working fine at japtrix and was tuned correctlly. The car would have been misfiring at japtrix if it was that...
Old Aug 3, 2007 | 08:43 AM
JBlueCLS6's Avatar
My car was running fine on boost too...then started throwing misfires.... then bye bye Motor.
Old Aug 3, 2007 | 09:18 AM
italiaCLs's Avatar
Well I hope it is not that. You really think it would go just like that? within a week.... ? hmm. I called japtrix and they said they will look at it and take care of whats wrong....what do you think is causing the misfires if it is tuned correctlly?
Old Aug 3, 2007 | 12:02 PM
CleanCL's Avatar
whats the code?
is your IMRC connected?
Old Aug 3, 2007 | 12:44 PM
italiaCLs's Avatar
Old Aug 3, 2007 | 12:45 PM
italiaCLs's Avatar
Originally Posted by CleanCL
whats the code?
yes. should i diconnect it?
Old Aug 3, 2007 | 01:43 PM
CleanCL's Avatar
yes. for however long you were on the HBP, you were silent detonating. chances are you did mess the motor.
Old Aug 3, 2007 | 03:02 PM
Moodist's Avatar
I hope your engine is ok! I dunno how many threads I read of HBP S/C folks not disconnecting their IMRC and messed up engines
Old Aug 3, 2007 | 03:58 PM
italiaCLs's Avatar
i cant believe it..... i asked the guy at the shop and he said that it was fine..... so my engine is toast...???? this is crazy... just from a few hard runs....
Old Aug 3, 2007 | 04:53 PM
JBlueCLS6's Avatar
Quite possibly man... you should never have the IMRC connected with the HBP on unless you had it tuned to provide more fuel during engagement.
Hopefully your engine didn't take a dump but I can relate =(
Old Aug 3, 2007 | 05:46 PM
italiaCLs's Avatar
what are signs of it taking a dump? becasue i didnt run it that long at all.... including the dyno pulls i WOT maybe 5 times...
Old Aug 4, 2007 | 10:15 AM
italiaCLs's Avatar
my engine is NOt blown!!!! it was the methanol that was injecting way to early and causing extreme rich AFR. The set it to come on at 5 lbs instead of 2 lbs of boost. We did some hard pulls a few times and it worked fine..... by the way the engine codes were all misfires because of the rich mixture.
Old Aug 4, 2007 | 12:43 PM
Moodist's Avatar
^ Glad to hear, so are you going to keep your IMRC connected still?
Old Aug 4, 2007 | 12:49 PM
Allout's Avatar
Blown is Best
That's great news!
I'm assuming that the Unichip was tuned to add fuel before IMRC and VTEC. Those appear to be the two main areas that the motor goes lean.
Do you know if this is what they did Italia?
Old Aug 4, 2007 | 09:24 PM
italiaCLs's Avatar
No. I disconncted it to be safe, even though they insisted that it was fine. big relief though. I just got back from picking up my CF hood too
Old Aug 4, 2007 | 09:26 PM
italiaCLs's Avatar
Do you know if this is what they did Italia?[/QUOTE]
yes thats the way they tuned it, for sure.
pette25
Aug 14, 2008 04:33 PM
CG2PROJECT
May 10, 2008 01:59 AM
wong05tsx
Oct 11, 2007 06:18 PM
oonowindoo
Oct 31, 2001 01:34 AM
