Some questions about getting 19s
I would like to get 19s on my Type S. I have a few questions though. If I have comptech springs would I have to worry about rubbing? What is the sizes I would need (offset, width, and tire size).
Thanks for your help.
Sorry I can't help... but maybe this will
http://www.acura-cl.com/forums/showt...threadid=61015
You can also do a search on stuff like rubbing, offset, etc. and I guarantee a bunch of matches.
You can get 19X8s with 235/35s, but the wheel needs an offset of at least 48, and hopefully somewhere closer to 50-51. An offset of 45 will still get you minimal rubbing according to members here.
Silver Bullet
18" ROH ADRENALIN
So basically, as long as the offset is greater than 48 the size of the wheel doesnt matter? What is the stock rims offset? Thanks
I am thinking of getting ROH ADRENALIN or the ADRENALIN black ice in 18 and I may lower the car down the road and I dont want to deal with any rubbing. Thanks...
The Creator
Re: 18" ROH ADRENALIN
diameter should always be the same as stock (wheel+tire) anyways...
so what matters is width & offset.
the trouble with larger diameter wheels is that their typically only available in large widths and low offsets.
+48 19x8 wide is best.
I have +45, 19x8 and I have minimal rubbing (with a drop much more then comptech)
any less then +45 and your outta luck.
then again... SOME wheels are available in 19x7.5 or 7.0 widening your choice in offsets.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
