Some CL Specs
www.drippinwet.com
Some CL Specs
Body Type All steel-unit body
Front Suspension Independent double-wishbone with coil springs and stabilizer bar
Rear Suspension Independent multi-link double-wishbone with coil springs and stabilizer bar
Shock Absorbers Gas-pressurized with Acura Progressive Valve technology, front and rear
Stabilizer Bars Front - 27.2 mm diameter (tubular) x 4.5 mm wall thickness
Rear - 18.0 mm diameter solid
(Type S - 19.0 mm diameter) solid
Steering Type Variable power-assisted, rack and pinion
Steering Wheel Turns,
Lock-to-Lock 3.2CL - 3.06
Type S - 2.88
Turning Circle,
Curb-to-Curb 3.2CL - 37.4 ft. (5.7 m)
Type S - 39.4 ft. (6.0 m)
Wheels 3.2CL - 16 x 6.5 JJ cast-aluminum alloy
Type S - 17 x 7.0 JJ cast-aluminum alloy
Tires 3.2CL - P205/60R16 91V Michelin MXV4-Plus
Type S - P215/50R17 93V Michelin MXM4 Pilot
Braking System Dual-diagonal, power assisted, 4-wheel disc brakes
Front Discs Ventilated, 11.8 in. (300 mm) diameter; 1.1 in. (28 mm) rotor thickness
Rear Discs Solid, 11.1 in. (282 mm) diameter; 0.35 in. (9 mm) rotor thickness
Anti-Lock Braking System (ABS) 3.2CL - 3-channel system with 4 wheel speed sensors and electric/hydraulic control
Type S - 4-channel system with 4 wheel speed sensors and electric/hydraulic control
Vehicle Stability Assist (VSA) Throttle control, fuel control, and 2-channel brake control utilizing yaw, lateral g, speed and steering sensors for traction control and stability enhancement ( available on the Type S only )
Transmission
5-speed Sequential SportShift™ automatic transmission with Grade Logic Control
Ratios (: 1)
1st 2.563
2nd 1.551
3rd 1.021
4th 0.653
5th 0.470
Reverse 1.846
Final 4.428
Capacities
EPA Passenger Volume - 90.0 cu. ft.
EPA Cargo Volume - 13.6 cu. ft.
Fuel Tank - 17.2 US gal. (65.0 L)
Crankcase Refill Capacity, including filter - 4.6 US qt. (4.4 L)
Cooling System - 7.8 US qt. (7.4 L)
Dimensions
(Exterior)
Wheelbase 106.9 in.
Track, front 61.1 in.
Track, rear 61.0 in.
Overall length 192.0 in.
Overall width 70.6 in.
Overall height 55.5 in.
Minimum Ground Clearance (non-load) 6.2 in.
Curb Weight 3470 lb. (3485 lb. with Navigation System)
Type S: 3510 lb. (3525 lb. with Navigation System)
Weight Distribution
(% front/rear) 63/37
(Interior)
Head Room Front: 37.5 in.
Rear: 36.7 in.
Leg Room Front: 42.4 in.
Rear: 33.0 in.
Hip Room Front: 52.9 in.
Rear: 50.4 in.
Shoulder Room Front: 56.4 in.
Rear: 54.2 in
Type S - 2.88
Turning Circle,
Transmission
Ratios (: 1)
1st 2.563
2nd 1.551
3rd 1.021
4th 0.653
5th 0.470
Reverse 1.846
Final 4.428
Capacities
Dimensions
(Exterior)
Wheelbase 106.9 in.
Weight Distribution
(Interior)
Rear: 36.7 in.
Rear: 33.0 in.
Rear: 50.4 in.
Rear: 54.2 in
If you have the specs for a Honda Accord v6..that would be helpful...then we can see what parts are the same...
Originally posted by acura_service:
<STRONG>Body Type All steel-unit body
Type S - 2.88
Turning Circle,
Transmission
Ratios (: 1)
1st 2.563
2nd 1.551
3rd 1.021
4th 0.653
5th 0.470
Reverse 1.846
Final 4.428
Capacities
Dimensions
(Exterior)
Wheelbase 106.9 in.
Weight Distribution
(Interior)
Rear: 36.7 in.
Rear: 33.0 in.
Rear: 50.4 in.
Rear: 54.2 in</STRONG>
Type S - 2.88
Turning Circle,
Transmission
Ratios (: 1)
1st 2.563
2nd 1.551
3rd 1.021
4th 0.653
5th 0.470
Reverse 1.846
Final 4.428
Capacities
Dimensions
(Exterior)
Wheelbase 106.9 in.
Weight Distribution
(Interior)
Rear: 36.7 in.
Rear: 33.0 in.
Rear: 50.4 in.
emailnatec
29
Sep 28, 2018 04:27 PM
4drviper
Sep 23, 2015 07:42 PM
