so my other headlight went out now!...help?
Old Nov 18, 2009 | 09:10 AM
evan03CL's Avatar
Wait...I just blacked out
Ok, so I put up a post a bit ago about my one headlamp going out (the HID), and now the other one is out too!
Just went out about a day ago, it went out...came back on...then went out for good. So no more night driving for me.
So this is a ballast problem correct? I'm just going to buy all new bulbs and ballasts anyways...but is this a common problem with OEM ballasts? (I'm not going to buy OEM replacements)
I had just recently cleared my headlights, could this have anything to do with the problem? I made sure they were sealed up really well too....
Old Nov 18, 2009 | 11:40 AM
aznboi2424's Avatar
if one side goes out, the other is not far behind. you can try switching out the bulbs to confirm that its the ballast or if its the bulb.
Old Nov 18, 2009 | 01:23 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
well... at least HID systems are CHEAP now!
now you'll have to decide what Kelvin rating you want... what a tuffy
and an OEM ballast is as much as a full HID setup with lights and install. so at least u can look at it that way.
I'd see it from the point of...,"oh now I can get a whole new headlight system and not have to worry about matching my old OEM ballast with a new aftermarket one."
It's probably easier to just buy the whole kit... though I haven't tampered with the lights on this car, I could only imagine it shouldn't be anything too strenuous.
Old Nov 18, 2009 | 01:53 PM
tnobori1's Avatar
Missing my
https://acurazine.com/forums/showthr...hid+conversion
^ Definitely the most helpful thread regarding headlights for our cars. I had the same issue as you and just bought my 3rd used ballast 2 weeks ago. I haven't had a chance to install the newest one yet, but the others were faulty. I spent much more doing it that way then just doing a conversion. Now my other one is going out, too! IMHO, either spring for brand new OEMs or just do a conversion. Good luck!
Old Nov 18, 2009 | 01:56 PM
Bighelln1's Avatar
6th Gear
This may sound kinda stupid but im new here and cant for the life of me figure out how to start a new thread? can somebody help me out please. And if i were you i would just buy an entirely new hid kit. http://www.carhidkits.com/acura-66/rsx-hid-kit-109/t. mine is in the mail right now. cant wait to put it in
Old Nov 18, 2009 | 02:04 PM
tnobori1's Avatar
Missing my
You probably don't have a high enough post count to post a new thread yet. Otherwise, the "New Thread" button is on the top left just above the Stickies. Welcome!
Old Nov 18, 2009 | 02:24 PM
^^ yes and you cannot send private messages to anyone nor can any of us to you..
Still don't like that friggin setup, but its a one time hurdle to jump. thank god
Old Nov 18, 2009 | 03:15 PM
evan03CL's Avatar
thanks for all the help guys, i'm going to order up a full HID kit (ballast/bulbs/etc.) and just replace it all at once.
Old Nov 18, 2009 | 05:52 PM
friesm2000's Avatar
B A N N E D
that is your problem is that they are used
Old Nov 18, 2009 | 06:30 PM
tnobori1's Avatar
Missing my
I know, but they both went out at once. $800 is a lot to spend on lights man!
Old Nov 18, 2009 | 06:37 PM
friesm2000's Avatar
B A N N E D
the bulbs are proably not necessary, cause i did one mine with a new ballest and it is fine (no bulb), so it should be only like $400, but hey at least you can just do both at the same (even if it is multiply times)
Old Nov 18, 2009 | 06:57 PM
OperationDarkie's Avatar
Ultra Negro
wow you guys must have crappy luck, I still have the original ballasts that came with my car back in 02 and have yet to have any problems with them.
I would change the bulb first before order any type of shit, start simple then get complex.
It saves money
Old Nov 18, 2009 | 07:36 PM
friesm2000's Avatar
B A N N E D
It saves money
mine is a 03 with 100K and the previous owner drove ALOT at night too so that matters some too, also the bulbs are NOT cheap for quality, local import parts store (not dealer, they are like $135) still want $100 per bulb
Old Nov 19, 2009 | 11:56 AM
dave586270's Avatar
Chamorro
Thats def the way to go. There is a conversion kit in the BM for $60. Check it out! GL with the conversion.
Old Nov 19, 2009 | 12:27 PM
I have a feeling those who have aftermarket suspension and or bigger wheels (lower profile tires) will have this ballast and light problem more than the rest.
Simply because the car will B taking bumps harder which will wear out certain components faster than they would normally.
Old Nov 19, 2009 | 01:16 PM
dave586270's Avatar
Chamorro
That could be a cause as well. I've been rollin on 19's goin for my second season now and running stock ballasts with new bulbs. It seems to just be an inherent problem with our car. Like the trans, and the brakes...lol.
Old Nov 19, 2009 | 01:33 PM
tnobori1's Avatar
Missing my
It saves money
It wasn't the bulbs, it was the ballasts. The OEMs are like $350 + tax, each.
Old Nov 19, 2009 | 01:35 PM
tnobori1's Avatar
Missing my
Supposedly, it has to do with water getting in the ballasts. I don't think a bumpy ride has too much to do with this particular part, but I do see your point on other parts.
Old Nov 19, 2009 | 03:37 PM
Ultra Negro
I drive my car to downtown Chicago at least 3 times a week, and with construction and what not I am always hitting some bumps, maybe some just have faulty ballasts or something.
Who knows.
Could be the weather, but my car is garage kept so that may be a plus.
Old Nov 19, 2009 | 03:52 PM
Well I solved the tranny problem, and the brake issue.... so one more to go!
my car has had all 106000kms driven in toronto... if you only knew how much shit they tear up here. and i got original lights and ballasts apparently. So I don't think bumps matter on the stock set-up. I think it's the stiffer set-up that inherit this issue... but that's simply speculation.
You can believe w/e the cause is, I'm just shooting out ideas
Old Nov 19, 2009 | 05:42 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
It saves money
Did u bay your car brand new? I dont understand whay everyone thinks all there parts are stilll original when they bought there cars used? You think the guy selling it to u is gonna say i replaced 2 ballast , 3 transmissions and 2 coil packs?
Old Nov 19, 2009 | 05:50 PM
friesm2000's Avatar
B A N N E D
mine lasted 100k before one of the ballests finally crap out, previous owner had no issues with them, (bought it from a customer, put a new ballest in , and has been fine for the last 4k or so
btw shop i work at has maintained since it had 7K on it, so we would have records of it
Old Nov 19, 2009 | 06:05 PM
i bought mine from a DLR, it had 81000kms on it... all service records on file, one owner, no accidents... so that's how i know
The one perk of getting a DLR car.. u know where it's been, how it's been treated, and how she's holdin up
Old Nov 19, 2009 | 06:43 PM
Ultra Negro
bought the car used from a guy I worked with, he showed me every single receipt of work that came with the car cuz he had some TLC thing fromt he dealership, nothing was ever replaced, other than a radio.
And as far as what I can tell, from looking the car over, everything still looks like OEM stuff.
Still have original rotors too 135k on them they probably need to be replaced soon though
Old Nov 19, 2009 | 06:47 PM
friesm2000's Avatar
B A N N E D
mine was not a DLR car i bought it private and the only time it was at the dealer other then when bought new was warrenty work
Old Nov 19, 2009 | 07:37 PM
StonedCL's Avatar
B A N N E D
I work at a DLR and every used car we sell we say "one owner all maintence done here ect..ect.." so i dunno if I would trust evrything people tell you... I am selling my car and told the guy its on its 3rd tranny, rotors warp, SRS light has been fixed by dlr 5 times and is still on, car misfires cuz the coil packs go out easy, and the headers make a horrible resonance noise.. oh and I replaced each ballast and bulb at least one time, but would u rather me lie to him..NO.. what do u expect when spending $3500 on my car..
I does drive GREAT and has a newly rebuilt tranny in it!
Old Nov 19, 2009 | 07:44 PM
friesm2000's Avatar
B A N N E D
that's why dealers are stealerships and liars
Old Nov 19, 2009 | 11:18 PM
Ultra Negro
Well thats all great and all but the guy is one of the guys i grew up with, and was in the military with him and he used to give me rides to work all the time, kinda like brothers almost, besides it was a highway only car, so you believe what you want, and ill believe what I want, and I trust him, he saved my ass in Iraq so thats good enough for me.
Hence the reason why I bought the car.
Old Nov 20, 2009 | 08:14 AM
it's hard to lie about the fact there has only been one owner when you have their name and address in ur hand,. plus carfax, and a shit load of other documentation, including acura's service records which match my other data to a tee.
definitely didn't get fooled on that point. that's why I paid up the nose in the grand scheme of things. looking back i could have nocked 2gs off my car, but i didn't give a shit and was in a rush.
Unlike my moms car she just got yesterday from the DLR, nocked them down from 25000 to 22 something
LOL it was all me too, i even told the salesman, "you make more off a used car than a new one so you can afford to drop the price SOME MORE." hehehe
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
