Should I..................
Old Aug 27, 2001 | 11:13 AM
johnny_2X's Avatar
Should I reset the ECU by disconnecting the battery if I got CAI, headers, exhaust work done? If so, how long do I leave the battery disconnected for and then once I start the car what do I do? Thanks.
Old Aug 27, 2001 | 11:20 AM
1StGenCL's Avatar
958 & 991
I have heard 15 minutes
Old Aug 27, 2001 | 11:24 AM
Scooter's Avatar
'Cooter
i heard about 30-45
Old Aug 27, 2001 | 11:38 AM
Scooter's Avatar
'Cooter
fuel mappings are constantly being modified based on your driving style, hence some people's claim that after they've revved the car high for a while, the car is peppy off the line...i was told after i received my CAI to make sure i rev somewhat high, like when merging onto the highway, to set fuel mappings in a higher range where the CAI performs better...driving on a road at constant speed will not really set mappings very well...u should vary your speed as if u were breaking in your car when it was brand new...it takes approx 75 miles to get a somewhat consistent mapping, then after that, it changes depending on how u drive...of course, i could b totally off; this is how i understood it at the time i installed my CAI in May.
Old Aug 27, 2001 | 11:52 AM
spiroh's Avatar
15 minutes will do just fine. Just disconnect the negative wire from battery.
Spiro
Old Aug 27, 2001 | 12:07 PM
johnny_2X's Avatar
Do you diconnect the negative wire for 15 minutes or the positive?
Old Aug 27, 2001 | 12:09 PM
BigPimp's Avatar
Originally posted by johnny_2X:
<STRONG>Do you diconnect the negative wire for 15 minutes or the positive?</STRONG>
Both. Dont forget to find your radio code before you do this, as you will need to put that in after you connect the batter again.
Old Aug 27, 2001 | 01:07 PM
Rock Dog's Avatar
FvCK KNvCKLE
Originally posted by BigPimp:
<STRONG>
Both. Dont forget to find your radio code before you do this, as you will need to put that in after you connect the batter again.</STRONG>
And the Nav code! If so equipped.
Old Aug 27, 2001 | 01:21 PM
HellaWhat's Avatar
*Hella* isn't a word.
Originally posted by Scooter:
<STRONG>i heard about 30-45</STRONG>
Not when I'm paying $2 a gallon!!!
Old Aug 27, 2001 | 01:23 PM
technoid's Avatar
Guyz, do I need to do this "battery disconnect" if the only mod I've got installed is headers?
