Which shocks should I buy
I am trying to decide on which shocks to buy and from where. I will be installing these with the neuspeed sport springs. I am primarily looking at the koni, koni/neuspeed shocks. The koni's are $557.22 from autocarparts.com. Or i can get the Koni/Neuspeed for $627.20 from neuspeed.com. Do you guys know anywhere else to get better prices then these? Also, do you think that the neuspeed/koni's are worth the extra money?
The Screeching Toyo's
Get the Koni's. You do not need to spend the extra money for the neuspeed ones. The only difference is that the neuspeed ones have 5 perches on them and the regular Konis only have two. I have mine on the top perch so I would never need the neuspeed ones. The perch allows you to lower you car more than with just the springs. I think each step is about 1/2 an inch lower. I would shop around a bit. I think you can get them closer to $500 shipped. I'm not sure. Good luck and keep us posted.
AztecRol
Your car looks nice. I really like how it looks lowered on your car. Hope mine turns out that good since I will have the same setup. I dont want 1 end higher than the other. Also can you see the green springs from the side of the car. Was thinking about just painting them black. What u think?
if your looking for a subsitute for the koni the tokico illuminas are a good choice too! ive had them for about 10,000 miles and they have 5 settings and i love the stiffness
sidemarker
sidemarker
If you don't want adjustabilty, & just want better then stock stocks, I have these Tokico HP shocks. I got them off of ebay for under $300 brand new. Here the guys current auction:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33590
I'm very happy with them. Only notice a difference in ride on rough roads.
Originally posted by brian6speed
AztecRol
AztecRol
I forgot one more thing, the neuspeed koni's are 20mm shorter than the regular konis. So you can go lower. I really don't think you will want to go lower though.
Just to let you know, I do have front and rear camber kits. I wore out the stock tires really fast without them.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
