Service Bulletins
1 Post
check out www.nhtsa.org and click on "service bulletins database" link near the top.
on bin laden
Service Bulletin Number: 011000
Bulletin Sequence Number: 187
Date of Bulletin: 0010
NHTSA Item Number: SB618768
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ELECTRICAL SYSTEM
Summary: SUBJECT REGARDING ETM FIX - KEYLESS RECEIVER LOCATION. *TT
Service Bulletin Number: 010101
Bulletin Sequence Number: 176
Date of Bulletin: 0101
NHTSA Item Number: SB617690
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE
Summary: TECH LINE SUMMARY REGARDING AIR CLEANER SEVERE CONDITIONS MAINTENANCE SCHEDULE. *TT
Service Bulletin Number: 01001
NHTSA Item Number: SB617703
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE
Summary: SOME VEHICLES WITHIN CERTAIN VIN RANGES MAY EXHIBIT EXCESSIVE CRANKING TO START THE ENGINE AFTER THE VEHICLE IS DRIVEN AND THEN PARKED (WITH THE ENGINE OFF) FOR ABOUT 15 TO 20 MINUTES. *TT
NHTSA Item Number: SB618766
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE AND ENGINE COOLING SYSTEM
Summary: ON SOME VEHICLES, FAULTY FRONT AND REAR WATER PASSAGE GASKETS AT THE FRONT CYLINDER HEAD CAN CAUSE A COOLANT LEAK NEXT TO THE EGR VALVE. *TT
Service Bulletin Number: 01011
Date of Bulletin: 0102
NHTSA Item Number: SB618754
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE COOLING SYSTEM:FAN
Summary: ON SOME VEHICLES, THE RADIATOR FAN AND / OR THE CONDENSER FAN RUNS CONTINUOUSLY; OR, IF THE FAN(S) RAN CONTINUOUSLY WHEN THE ENGINE WAS OFF, THE BATTERY MAY BE DISCHARGED. *TT
Service Bulletin Number: 010200
Date of Bulletin: 0002
NHTSA Item Number: SB618757
Make: ACURA
Model: 3.2CL
Year: 2001
THER PARTS
Summary: BRIEF INFORMATION ON TROUBLESHOOTING THE ENGINE COOLANT TEMPERATURE (ECT) SENSOR. *TT
Service Bulletin Number: 160301
Bulletin Sequence Number: 198
Date of Bulletin: 0103
NHTSA Item Number: SB619902
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE
THER PARTS
Summary: INFORMATION ON VEHICLES EXHIBITING DIAGNOSTIC TROUBLE CODE P1486 AND / OR P0128 THERMOSTAT PERFORMANCE. *TT
NHTSA Item Number: SB617701
Make: ACURA
Model: 3.2CL
Year: 2001
Component: EQUIPMENT:ELECTRIC EQUIPMENT:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Summary: BRIEF INFORMATION REGARDING BLANK NAVIGATION DISPLAY CONDITION. *TT
Service Bulletin Number: 010301
NHTSA Item Number: SB619907
Make: ACURA
Model: 3.2CL
Year: 2001
Summary: INFORMATION ON THE NAVIGATION SYSTEM 4-DIGIT SECURITY CODE. *TT
NHTSA Item Number: SB619908
Make: ACURA
Model: 3.2CL
Year: 2001
Summary: INFORMATION ON TROUBLESHOOTING NAVIGATION SYSTEM DVD READ ERROR MESSAGE. *TT
NHTSA Item Number: SB617697
Make: ACURA
Model: 3.2CL
Year: 2001
Component: INTERIOR SYSTEMS:ACTIVE SEAT AND SHOULDER BELTS AND BELT ANCHOR
Summary: INFORMATION ON REPLACING SEAT BELT TENSIONERS AFTER DEPLOYMENT. *TT
Service Bulletin Number: 010201
NHTSA Item Number: SB619888
Make: ACURA
Model: 3.2CL
Year: 2001
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR
Summary: INFORMATION ON TROUBLESHOOTING DIAGNOSTIC TROUBLE CODE P0138. *TT
Service Bulletin Number: 01013
NHTSA Item Number: SB619881
Make: ACURA
Model: 3.2CL
Year: 2001
Component: INTERIOR SYSTEMS:PASSIVE RESTRAINT:AIR BAG IMPACT SENSOR
Summary: A CONDITION MAY EXIST WHERE THE SRS INDICATOR IS ON AND DIAGNOSTIC TROUBLE CODE 15-3 (FAULTY OPDS SENSOR) IS SET. *TT
Service Bulletin Number: 00033
Bulletin Sequence Number: 155
Date of Bulletin: 0011
NHTSA Item Number: SB615580
Make: ACURA
Model: 3.2CL
Year: 2001
Component: INTERIOR SYSTEMS:PASSIVE RESTRAINTS
Summary: SOME 2000 3.2TL AND 2001 3.2CL MODEL VEHICLES MAY EXHIBIT THE SRS LIGHT ON WITH DIAGNOSTIC TROUBLE CODE 15-1 (FAULTY OCCUPANT POSITION DETECTION SYSTEM UNIT) STORED. *TT
NHTSA Item Number: SB619900
Make: ACURA
Model: 3.2CL
Year: 2001
Component: POWER TRAIN:CLUTCH ASSEMBLY
THER PARTS
Summary: SUBJECT REGARDING AUTOMATIC TRANSAXLE CLUTCH PRESSURE SWITCH. *TT
NHTSA Item Number: SB619906
Make: ACURA
Model: 3.2CL
Year: 2001
Component: STEERING
Summary: INFORMATION ON VEHICLE STABILITY ASSIST ACTIVATING TOO SOON. *TT
Service Bulletin Number: 00032
NHTSA Item Number: SB615579
Make: ACURA
Model: 3.2CL
Year: 2001
Component: STRUCTURE:BODY ROOF
Summary: ON ALL 1999-01 3.2TL, 2001 3.2CL AND 2001 MDX MODEL VEHICLES, THE MOONROOF SEAL SQUEAKS AGAINST THE ROOF WHEN THE GLASS IS CLOSED AND THE SUNSHADE IS OPEN. *TT
NHTSA Item Number: SB617694
Make: ACURA
Model: 3.2CL
Year: 2001
Component: TRACTION CONTROL SYSTEM
Summary: TECH LINE SUMMARY REGARDING THE TRACTION CONTROL SYSTEM. *TT
NHTSA Item Number: SB619896
Make: ACURA
Model: 3.2CL
Year: 2001
Summary: SUBJECT REGARDING TRACTION CONTROL SYSTEM (TCS) OPERATION. *TT
NHTSA Item Number: SB617695
Make: ACURA
Model: 3.2CL
Year: 2001
Component: VISUAL SYSTEMS:WINDSHIELD WIPER
Summary: TECH LINE SUMMARY REGARDING THE INTERMITTENT WIPER FEATURE. *TT
NHTSA Item Number: SB619886
Make: ACURA
Model: 3.2CL
Year: 2001
Summary: SUBJECT REGARDING CURRENT VARIABLE INTERMITTENT WIPERS SPEED SENSITIVE. *TT
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
Make: ACURA
Model: 3.2CL
Year: 2001
Component: ENGINE
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Component: STEERING
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
Make: ACURA
Model: 3.2CL
Year: 2001
on bin laden
NHTSA Item Number: SB618767
Make: ACURA
Model: ACURA
Year: 2001
Summary: INFORMATION ON NEW LUBRICANTS AND COOLANTS. *TT
Bulletin Sequence Number: 157
NHTSA Item Number: SB615753
Make: ACURA
Model: ACURA
Year: 2001
Component: ENGINE
THER PARTS
Summary: SUBJECT REGARDING P1259 AFTER BARE BLOCK REPLACEMENT FOR 2001 3.2CL, 2001 MDX, 1999 - 2001 3.2TL AND 1997 - 1999 3.0CL MODEL VEHICLES. *TT
Service Bulletin Number: 011100
NHTSA Item Number: SB615747
Make: ACURA
Model: ACURA
Year: 2001
Summary: SUBJECT PERTAINING TO THE LATEST NAVIGATION SYSTEM DVD SOFTWARE FOR 2001 3.2CL, 2001 MDX, 2000 - 2001 3.2TL, AND 2000 - 2001 3.5RL MODELS. *TT
NHTSA Item Number: SB615748
Make: ACURA
Model: ACURA
Year: 2001
Summary: INFORMATION ON THE NAVIGATION SYSTEM COVERAGE AREA FOR 2001 3.2CL, 2001 MDX, 2000 - 2001 3.2TL AND 2000 - 2001 3.5RL MODELS. *TT
Make: ACURA
Model: ACURA
Year: 2001
Make: ACURA
Model: ACURA
Year: 2001
Component: ENGINE
Make: ACURA
Model: ACURA
Year: 2001
Make: ACURA
Model: ACURA
Year: 2001
on bin laden
Service Bulletin Number: 300501
NHTSA Item Number: SB619878
Make: ACURA
Model: CL
Year: 2001
Component: ELECTRICAL SYSTEM:BATTERY
Summary: AMERICAN HONDA, HONDA OF AMERICA MANUFACTURING, AND DELPHI WILL CONDUCT THE RETURN OF CERTAIN DELPHI BATTERIES. THE BATTERIES INVOLVED ARE DELPHI FREEDOM GROUP SIZE 35, CCA 440. *TT
Make: ACURA
Model: CL
Year: 2001
Component: ENGINE
THER PARTS
NHTSA Item Number: SB615751
Make: ACURA
Model: CL
Year: 2001
Summary: ON SOME VEHICLES, THE PGM TESTER DOES NOT RECOGNIZE SIDE AIRBAGS. *TT
NHTSA Item Number: SB618762
Make: ACURA
Model: CL
Year: 2001
Summary: INFORMATION ON PROGRAMMING THE IMMOBILIZER KEYS. *TT
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
NHTSA Item Number: SB615758
Make: ACURA
Model: CL
Year: 2001
Summary: INFORMATION ON WINDSHIELD WIPER SMEARING AND STREAKING. *TT
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
Component: ENGINE
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
Make: ACURA
Model: CL
Year: 2001
on bin laden
most people only look at the info for 3.2 CL, but there is more stuff for our car if you look around a bit. sorry for trying help. i didn't realize friday was "be a dick" day
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
