Serpentine Belt Removal-NEED HELP NOW-
Old&CnL
The car is up on Jacks, I am ready to remove the crank pulley, but I can't find how to remove or loosen the larger belt- I see no adjustment for the spring tensioner- need some advise fast!!!! All you guys out there, please advise or send me a DIY link.
Thanks in advance-
Thanks in advance-
yea, there is a bolt in the center, just push it backwards to release the tension on the belt.
Its not the easiest to see as it is in a tight spot, but its there.
Old&CnL
Update:
The starter method almost worked; the socket split in half from the torque exerted, and since my wife wasn't home, I had to close everything up and wait until I could get an impact strength socket. I was using a 3/4" but I think 19mm is the correct metric. Will try again today or tomorrow.
Rats
Rats
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
