Saving an 03 CL-S 6Spd
Old Mar 21, 2021 | 08:46 PM
  #161
^Hey Acura2g558, can you post a few detailed pictures of the new JSwapShop CL-S6 torque dampers when you get them?
Thanks!
Old Mar 22, 2021 | 05:31 AM
  #162
Acura2g558's Avatar
Thanks!
Absolutely. I'm going to do a video on them too
Old Mar 26, 2021 | 12:35 PM
  #163
skater03CLS's Avatar
Hey there! I am the only owner of a 2003 CL Type S. Very nice to see this one continuing to live on! 18 years old and about 130k miles and mine still runs and drives great!
Old Apr 17, 2021 | 03:11 PM
  #164
Acura2g558's Avatar
First part review
Old Apr 24, 2021 | 12:54 PM
  #165
Acura2g558's Avatar
Old Apr 24, 2021 | 02:14 PM
  #166
The guy below kind of shows what you were explaining in regards to seal / piston insertion?
He has the added fitment of a metal 'snap ring', to secure the boot, for his MDX calipers, though.
Old Apr 25, 2021 | 04:08 PM
  #167
Acura2g558's Avatar
Correct. Takes a bit to get correct
Old May 2, 2021 | 04:20 PM
  #168
Acura2g558's Avatar
Thanks!
I purchased these, but there were just too many differences to make me believe they would work. Travel was way off, the bottom bushing didn't seem correct at all.
Old May 2, 2021 | 04:28 PM
  #169
Interesting.
Can you post a few pics scaled next to something?
From the pictures on his FB page I was able to determine they were 'golf cart' related, so?
Old May 2, 2021 | 06:49 PM
  #170
Acura2g558's Avatar
Interesting.
Old May 6, 2021 | 09:59 AM
  #171
Acura2g558, can you make that 'engine damper' video public so that we can observe your findings?
Old May 6, 2021 | 04:07 PM
  #172
Acura2g558's Avatar
Rookie move
Try it now.
Old May 11, 2021 | 08:28 PM
  #173
Acura2g558's Avatar
Old May 13, 2021 | 10:24 PM
  #174
619rcr's Avatar
Nice vid writeup.
Looked for dual piston Legend dual pistons and NSX Calipers on Rockauto a few months ago & they are no longer avail.
Old May 13, 2021 | 10:59 PM
  #175
Keith Abner's Avatar
kykeith
cls6
I have 2 '03 cl type-s 6mt
, I drive trucks for a living, drive my 190k cls6 50 miles a day, 6 days a week. restoring a unicorn cls6 white on black with navi on the side.
Old May 14, 2021 | 06:05 AM
  #176
Acura2g558's Avatar
Originally Posted by 619rcr
Nice vid writeup.
In part 1 video I quickly cover how i had to get mine. I had to find them in a salvage yard and rebuild.
Old May 14, 2021 | 06:06 AM
  #177
Acura2g558's Avatar
Nice! Many parts are still available from Acura. I highly recommend enthusiast snatch them up before they are all gone and get used for cars that will end up in the crusher. I got the last left muffler
Old May 14, 2021 | 04:42 PM
  #178
Thefireball's Avatar
I am dumb
Your brake caliper video was recommended to me on YouTube back when it was first posted, and I was curious as to why you decided to go with legend calipers and not the RL calipers?
Was going to ask it on YouTube originally, then I saw you were posting on here, lol.
Old May 15, 2021 | 07:05 PM
  #179
Acura2g558's Avatar
The RL calipers are an excellent option. I was looking for a more period correct replacement and the RL calipers just wouldn't give that look and I don't require the performance upgrade for the job the car is doing.
Old May 16, 2021 | 01:01 PM
  #180
I am dumb
Makes sense, and I agree with you.
Old Sep 15, 2021 | 07:06 PM
  #181
Hey Acura2g558, I just watched your 'crank no start' video and suspected it was the main relay assembly. Having had gone through this very same situation twice now down here in the heat of FL already. You are brave reflowing the solder versus purchasing new.
Regarding the crank sensors for the CL-S6, should you have the 'discontinued' transmission side one go on you (
37506-PGE-A12) you can substitute it with an OEM from many Honda models part # 37500-PNB-003 or from an Acura 02-06 RSX with the same number before having to resort to aftermarket, if there is even one available.
Old Sep 15, 2021 | 08:16 PM
  #182
Acura2g558's Avatar
Thanks Zeta, gold level knowledge as always! Do you know if there is a replacement for the discontinued cranks sensor for the one on the bottom of the timing belt?
I'm a bit brave for sure with the resolder, but oddly it hasn't reoccurred since that repair *knock on wood*
​​​​​thanks for watching the video ✌️
Old Sep 15, 2021 | 08:31 PM
  #183
When I search on 37500-PGE-A11 for that pulley side OEM crank sensor, it still comes up available on the Acura vendor sites?
However, RockAuto has some pricey aftermarket equivalents WVE$229.79; NTK$314.79 versus the OEM $92.41.
The pulley side crank sensor sub-harness, though, is 'discontinued' so we all have to be careful not to shred a timing belt and destroy what we have.
Old Sep 16, 2021 | 05:51 AM
  #184
Acura2g558's Avatar
Good sleuthing, thanks. I hope they are still available.
With everything going on in the world a lot of the parts I've tried to word through online OEM parts have ended up being cancelled with the reason "backordered."
Old Oct 2, 2021 | 02:01 PM
  #185
Acura2g558's Avatar
Old Mar 13, 2022 | 09:46 PM
  #186
Acura2g558, don't know if you noticed; however, you can observe the PS fluid level in the reservoir fall sharply, just after start-up, at about the 08:11 time stamp on your 26Feb2022 video.
Old Mar 14, 2022 | 09:16 AM
  #187
Acura2g558's Avatar
This was the first start post the P/S pump rebuild video that I did. I expected a sharp drop initially, but little did I know the pump case cracked.
Old Mar 14, 2022 | 12:23 PM
  #188
...but little did I know the pump case cracked.
So if the P/S case crack was in the general thread area of the 'red' arrow, would it be the result of, perhaps, over torquing the flow control valve cap when replacing the o-ring 'gasket' on your rebuild video??
Factory spec: 36lbf-ft seems like a lot for an aluminum case, though?
Old Mar 14, 2022 | 12:37 PM
  #189
In addition, since the OEM and Rockauto one's are a little pricey, you may be able to just get away with replacing the p/s case?
Car-part.com has a couple $45 pumps available in Colchester, VT.
Old Mar 14, 2022 | 01:57 PM
  #190
Acura2g558's Avatar
Well, you nailed it. I'm going to be releasing a follow-up video. I didn't have the proper tool at the time to torque down the flow control valve cap so I followed the German approach of "Goo-d and tiight" but the result was catastrophic failure. I like your recommendation of "car-part.com" but I found a LKQ 54k mile P/S pump near me and had it shipped for free. Needless to say, now i have the gaskets to rebuild it when it fails, but for now i should be good. Lessons learned.... funny thing is, I almost always use a torque wrench (if you follow my videos you can see that) and this is one of the very few times i didn't and oh did i pay.
Old Oct 24, 2023 | 09:55 AM
  #191
Hey @Acura2g558 , just curious, where / when did you hear the claim you made, on your video below, that Acura / Honda were switching over to Mahle for almost all of their OEM sourced parts?
I used your video statement, on the thread below, to suggest an alternative to the OP for a thermostat he may need & as predicted there is 'push back', lol.
Thermostat. Rockauto or oem? - AcuraZine - Acura Enthusiast Community
rockstar143
Dec 7, 2023 10:27 AM
M T L T L
Oct 9, 2013 06:43 PM
A418t81
Jul 2, 2012 05:19 PM
suspekt360
Dec 22, 2011 09:11 PM
The Negotiator
3G TL Photograph Gallery
25
Jul 20, 2010 01:06 AM
