For Sale: Turbo Kit For 2003 CL 6 Speed
The time has come as I have another project in the works.
https://acurazine.com/forums/showthr...20#post5336820
The kit is awesome and everyone knows Ram built it originally. It performs flawlessly and I have upgraded many of the parts and have added many extra items.
Whoever has the balls to buy this thing will get everything needed to terrorize Vetts to Porshe. It's not for the light hearted.
Here is a rundown of parts.
1) Garrett GT35R BB .82ar, 84trim, compressor side
.70ar, trim
2) Complete piping from the charge pipe, IC pipe to the
down pipe. All custom fitted and will fit perfectly.
3) Oil pan with oil return fitting, the pan has also been
modified to better clear the manifold plumbing.
4) All stainless steel fuel lines, fittings, stainless steel
braided oil feed line, fittings to feed oil to the turbo,
stainless braided return line. Basically, every pretty
fitting you can think of.
5) Emanage Blue with two (2) maps. One tuned for 6psi
on 93 octane, and the other tuned to 10psi on race gas.
This includes the custom harness that is PNP into your
ECU.
6) Tech-Edge Wide band AFR with new sensor, or I should
say it has only about 1000 miles on it.
7) Dual gauge pod with Autometer electric boost gauge &
Fuel Pressure gauge. This includes the sending units.
8) Electromotive Knock Link, lights up and warns you of
detonation.
9) RC 440 injectors with injector clips and modified
fuel rail.
10) Thermoblock Spacers
11) Aquamist Water/Methanol injection Kit
12) Aeromotive 1:1 Fuel Pressure Regualtor
13) APEXi AVCR electronic Boost Controller, complete.
14) Tial Blowoff Valve
15) Tial Wastegate with two springs, roughly 4lb and 6lb.
16) Not sure of the make, but an air to air FMIC.
17) All Exhaust Manifold Piping has been coated, Jet Hot.
I added the AVCR, Aeromotive FPR, Thermoblock Spacers,
RC injectors, modified the fuel rail, Jet Hot the exhaust manifolds and upgraded the fuel and oil lines with new fittings, added the Greddy Pressure sensor to the Emanage Blue, and spent huge bucks on two tunes that are included.
This is for a 6 speed model only. It will not work on the automatic cars.
The kit is in excellent condition and works perfectly.
$ 7200.00 shipped, or $7000.00 plus shipping.
.70ar, trim
ECU.
detonation.
fuel rail.
cycdaniel
12-17-2019 11:58 AM
handsom-hustla
11-13-2015 06:04 PM
