S/c Ic
Old Nov 18, 2005 | 03:08 PM
All Mine's Avatar
I'm a Vagiterian.
S/c Ic
Is there just one IC made for the CT S/C? I know if you run an HBP, an IC should be used in conjunction. The only one I know of is the Hope IC system.
Old Nov 18, 2005 | 03:18 PM
spdy0001's Avatar
I now drive an accord....
Yes HOPE is the only one, and most people who run the HBP don't have an IC
Old Nov 18, 2005 | 03:34 PM
typeR's Avatar
anyreason a front mount like that used on the turbo kits couldnt be used
Old Nov 18, 2005 | 03:41 PM
All Mine's Avatar
I'm a Vagiterian.
So it's a front mount that feeds to the intake manifold directly?
Old Nov 18, 2005 | 04:06 PM
AcuraFan19's Avatar
http://www.modacar.com/products/Acura/CL/MODANIO/
third from the top... seems like an interesting idea.
Old Nov 18, 2005 | 04:13 PM
PiMpiN wHITe Cl-S's Avatar
^ for that to work, you would need an intercooler first. that item you are referring to sprays nitrous into the intercooler.
Old Nov 18, 2005 | 04:40 PM
AcuraFan19's Avatar
ah... thx for the info
Old Nov 18, 2005 | 04:41 PM
bigguyonbike's Avatar
13.2 @ 104.76mph
i have a hope system intercooler for sale in black market if anyone is interested.
Old Nov 18, 2005 | 04:52 PM
^ thats a clean element you have there. always liked that car.
Old Nov 18, 2005 | 06:22 PM
Chemmech's Avatar
I see in your sig 13.2 , that's an awesome time. Was that with the IC installed?
Old Nov 18, 2005 | 08:57 PM
13.2 @ 104.76mph
^ yes, but the water in the tank was hot and the car pulled alot of timing. i think it would have been possible to get into the 12's with good traction and ice in tank.
Old Nov 18, 2005 | 10:45 PM
Chemmech's Avatar
I have the ic kit too. I removed everything awhile ago, but will be reinstalling it soon. Didn't want a denied warranty on my bad tranny. Anyway, this time around I will be running lower boost, I'm tired of all that arise from 9psi, burnt plugs ect. The Ic should still net me some good power with moderate boost . Just got the Ic pump and resevoir in along with my high volume fuel pump, tranny cooler, new wilwood ceramic brake pads, brake fluid flush and some wiring is done. Next week I'll install the s/c'er & Ic manifold.
Old Nov 19, 2005 | 05:06 AM
ThinJim's Avatar
I'd wondered what happened to you, but glad your still in the saddle. That is one of the smart things to do in the event of a failure like that. Take the time to remove everything and put back to stock for the warranty.
Old Nov 19, 2005 | 09:03 AM
Chemmech's Avatar
I got ea few snickers from the parts guy, I guess the tranny was totally toasted. The techs knew something was up, you can remove the mods, but you can still see that it just didn't look right. The parts guy even asked me if I was gonna put the super charger back on .
Old Nov 19, 2005 | 01:03 PM
Allout's Avatar
Blown is Best
I've been pretty luck so far with my mods. Built a pretty good relationship with the Service Manager. He hadn't driven a SC'ed 6 speed so I threw him the keys and told him to have fun.
Old Nov 19, 2005 | 01:45 PM
Chemmech's Avatar
Woo Hoo!!! Damn brakes are working good ! No more screeching. The Tranny is runnin alot smoother with the cooler. My horsepower is definately Up too. I found 2 rags stuffed up in the bottom side of my intake, not sure if it was me or the Dealership . I thought my car was over the hill or something for a long time.
It's been a good day .
Old Nov 19, 2005 | 03:14 PM
Allout's Avatar
Blown is Best
Excellent
The tranny cooler makes a world of difference on the Auto. I've been running Amsoil Synthetic Tranny fluid which is Z-1 rated and I've been pretty happy with it in the TL-P.
What type of boost levels are you going to be running this time around? HBP?
Old Nov 19, 2005 | 04:01 PM
Chemmech's Avatar
I'm gonna try to run around maybe 6 psi. With the 9 psi setup, my fuel mileage was about 7 mpg. Anyway, I've been thinking about something though. The pcv valve, does it act as a check valve when the manifold is under boost??? Might be able to reroute some hoses to make more boost, if the pcv isn't a check valve under boost.
Old Nov 19, 2005 | 07:35 PM
ThinJim's Avatar
it is a checkvalve, only flows one way...only under vacuum
StYLeZz101
Feb 23, 2008 03:27 AM
RYAN97812
Feb 12, 2008 04:27 PM
NJTSXMan
May 25, 2007 12:31 PM
Chemmech
Jul 3, 2006 07:36 PM
