Running 110 high octane ?
I am thinking the next time I go to the track. I'm going to get there on a very low tank of gas. Do a few runs then add the 110 and flip the switch on the unichip to see if there is any difference. Now when i'm done and go back to map A is it ok to run that high of octane if the car doesn't really need it until I can get 93 back in it?
Gimmie my points Biatch!
Never thought about that. I forgot that they still make leaded fuel. THANKS!
louie,
additionally, lead was used to allow the valves cushioning when contacting the valve seats in the heads the cast heads used on some race engines still require the lead additive most notibly "vintage Racers and many 1950"s 1960's muscle cars. today's fuels use different additives to boost octane. 110 race fuel such as found at many race tracks are usually leaded. aviation fuels are usually leaded 115 octane rated. some sonoco fuels can be purchased drop shipped in 104, 110 and 115 rated octane non=leaded,very expensive. some sun oil co stations sell 100+ octane pump fuel, non leaded i believe
Thanks for the help Auclsman. The track that I'm referring to that has the 110 is Greatlakes drag in union grove. Are you familar with the gas at this track since your in wis.
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
