rubbing
Old Apr 11, 2002 | 07:06 AM
ch1276's Avatar
rubbing
I know this has probably been asked already, but I just wanted to check......I have a 2003 CL-P and want to put in Comptech springs and 18 inch rims.....has anyone had any rubbing problems with their cars?
Old Apr 12, 2002 | 09:05 AM
ch1276's Avatar
i would appreciate any help on this...i was hoping to order the rims this weekend and was looking for some feedback....sorry if this has been asked before, but search is not working....
Old Apr 12, 2002 | 09:43 AM
WebToker's Avatar
Re: rubbing
No...
Old Apr 12, 2002 | 09:52 AM
soopa's Avatar
The Creator
Cal, did you get your wheels on?
Old Apr 12, 2002 | 10:03 AM
WebToker's Avatar
They come in Monday, been tracking them, so I went ahead and setup an appoinment Monday morning to have my alignment done before I put the wheels on. I can't wait!
Old Apr 12, 2002 | 10:45 AM
Z's Avatar
Z
Just get a high offset like 48mm or higher and you'll be in the clear... you'll even be able to slam it ... dont use comptech get eibac (sp)
Old Apr 12, 2002 | 11:04 AM
4pumpedCL's Avatar
Honkey
Are you nuts? If you get 18's you'll throw off the calibration of your speedometer. You're have a noisy, harsh ride. Not to mention HEAVY wheels that will ruin you 1/4 mile. You're crazy man!
the above is all false.
Old Apr 12, 2002 | 11:26 AM
Nicky Pass's Avatar
Fuct in the hed!
I have 19"s(+45 OFFSET) with comptech springs and I have never rubbed ever!
Old Apr 12, 2002 | 11:32 AM
Shawn S's Avatar
I have 18” Wheels with Comptech springs and ZERO problems.
Just be sure to check the RIM width and offset.
Mine are 7.5” wide and have an offset of +48.
A wider wheel or lower offset could give you problems.
Post the specs on the RIMS you're getting and see if anyone jumps in that may have them.
Shawn S
Old Apr 12, 2002 | 02:37 PM
Z's Avatar
Z
the reason i said to get 48mm or higher is if he uses springs with a lower ride hieght than comp. he still wont have a any rubbing.....
I guess I'm just in to the squatted, stuck to ground; can turns a 1000mph look
Old Apr 13, 2002 | 12:57 PM
ch1276's Avatar
thanks guys...ordered them today 18x7.5 lowenhart LD1's with 235/40/18 tires and comptech springs
Old Apr 13, 2002 | 01:01 PM
Nicky Pass's Avatar
Fuct in the hed!
Good Choice!!!!!!!!!
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Tribalheads
Sep 29, 2015 03:24 PM
