Rpm really high only when hot outside in traffic
Old May 6, 2014 | 09:41 PM
Je357's Avatar
6th Gear
My rpm stick around 3 k when it's hot out in traffic. But once I start moving and get some open road. Car is normal. Sucks when this happens cause I have to keep foot firmly on brake cause car wants to go really hard once I let off brake. I have no check engine light. The throttle plate is clean. Car idles fine in the morning. Even all winter nothing happened. Only have this problem in summer time?
Old May 7, 2014 | 04:47 PM
Karanx7's Avatar
Unregistered Member
Kind of hard to diagnose if it's intermittent. Might be best to take it to a mechanic. Try checking the IACV.
Old May 9, 2014 | 05:20 AM
YeuEmMaiMai's Avatar
plug in a scan tool that has real time data ability and see what is going on... sounds like a TPS failure to me or a vacuum leak
Old May 9, 2014 | 07:45 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Vac leak I would guess.
But usually it's the other way around the warmer the car is the more the idle drops. I agree with yeuemmaimai with the real time data scanner.
Or else you may waste hours and hours beating around the bush
Old May 22, 2014 | 10:55 AM
cl82793's Avatar
high rpm
had this happen too, definitely heat related . would be interested in diagnosis or replies.
Old Oct 15, 2014 | 10:15 PM
mpgilroy77's Avatar
5th Gear
I've had this problem on my 01 CLS for the last couple of years. Bumper to bumper traffic in 70+ deg weather and it creaps up slowly from normal idle to 2200 rpm. I actually drove it into the Acura Dealer with the idle at 2000+ rpm. They can't figure it out. I've replaced two idle control valves, and after they wanted to swap it out again, I got ugly and now they are telling me it is the throttle body sticking. They cleaned it out (again) and its been OK, but I had this just happen again where I got stuck in traffic due to an accident.
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
rockyboy
Sep 29, 2015 12:05 AM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
