Rough Idling?
Rough Idling?
Need your help...I've got the '03 6-speed and was wondering if anyone has noticed that when your car is stopped (like at a light or when parked), do you experience the car shaking a bit rough?
Maybe I'm just anal and the car is supposed to vibrate a little, but I don't recall being in any car that really vibrates at a stop.
What do you think? Could probably live with it for now...it's a pain going to the dealer 'cause it's 30 miles away and I don't have the time.
Re: Rough Idling?
Mine does the same thing - 1700 miles, 6 weeks old. I can't recall, but I don't think mine gets better as it warms up. It really just seems to idle roughly, almost like an old muscle car that had the timing adjusted.
What disturbed me most about it was when it was idling rough, I gunned it a few times (in neutral), and as the revs came back down it stalled.
On the flip side, I think that having the idle so low makes it extremely difficult to stall the vehicle on launch, which is nice.
My AT CLS does the same thing when the weather is cold. Seems like until the engine is completly warmed up, the idle is rough and bounces around some
maybe...
Yea it has to do with warm up but remember CL is known for being a luxery SPORTS car. So if you guys know alot of sports cars.. there usually not the best ride or you will hear engine noises sometimes (which is normal). Thats why CL is also a little rougher ride then most other luxery cars b/c of its sports orgin. GOtta love the CL :P
The idle on mine is not too bad...it's not like it's very strong and rough, but just slightly and it kind of annoys me. I'm in Arizona and it's not too cold outside anyways...although this week it's a little cooler than normal. But I will try to let it warm up first later today when I leave work and see how it drives.
useph_murray...keep us posted what the dealer says. Perhaps this isn't a problem and it's normal like what lilman is saying.
If it happens after some miles have been put on it (especially some hard ones) and the rough idle improves with some throttle, I think of a motor mount. When Acura replaced my trans 2 wks ago they also replaced a cracked motor mount the mechanic found. I really didn't notice a rough idle before, but I can DEFINITELY tell you it is smoother now at idle and realize it is now correct. I had a new '85 944 that went through motor mounts like crazy back then. You could always tell when they went bad. But, on a brand new car I wouldn't think a motor mount would be that likely unless the 6 speed puts more stress on the mounts from dropping the clutch, etc.
Re: Rough Idling?
Still does it. My '01 auto never did it. I don't know if it's because of the extra motor mount, or how the engine is mounted, but at a light (with the clutch in Scalbert!), it's got a fair amount of shake. Reminds me of my old beater when you'd retard the timing at idle.
Gotta be the cold weather. It seems that any annoying and/or weird thing with the CLS (rattles, weird idle, weird tranny noises - excluding failure, of course) is related to the cold.
Originally posted by pluto_1969
Mine doesn't idle steady as a rock at 9,025 rpms... but it's not fluctuating wildly either.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
i hate to sound like a broken record...but rough idle,resonance,.rattles,all gone now that i have two new motor mounts...they are liquid filled so i assume just a tear is all it would take....
look closely at the rear one, use a flash light...have someone put the car in drive/then reverse,with foot on brake with just enough gas to get the engine to load up....the TSB for the rear motor mount specs to rough idle and or stall,as symptoms
between the mounts and the rotors...my car feels like brand new...i didnt realize what a difference there was
Damn, hopefully it's my motor mounts are cracked. Well, maybe I'll try to find some time next month to take my car in and have the dealer look at it. They were supposed to call me in January to have the regional Acura rep to take a look at my paint. So since I think I'll be taking a week or so off of work next month, I'll have the time to drive up to the dealer and have them check out these things. Between the paint quality, rough idling, and getting my hand brake retightened, the car is great. No real major problems that would prevent me from driving.
If you guys get this idling thing checked out, please let me know what the dealer says. I want to see if there is anything common for this sort of problem.
Originally posted by scalbert
I hope it doesn't idle well at 9,025 revs. That nearly 8,500 revs over what the stock car should be at... In fact, my car does drive well at over 9 grand on the tach; valve float is a biatch...
:P
btw, nice avatar... big tool fan?
Anyone else take their car in to get this checked out? I'm gonna call my service advisor at Acura to maybe setup an appointment. I want to have them look at my paint and get my hand brake adjusted again. Hopefully I don't have to pay for anything...I know they like to use the line that if they inspect it and nothing is wrong, I'd have to pay.
The CL Crazy
I noticed it also a couple of weeks ago. Only does it when the car is in park and it is warmed up. It seems to shake a bit on idle. I just took it in today to get it check out. I will let you know the results when i pick it up later today.
CT3.2 - do let me know. I called and asked the advisor about it and he said it may not be a problem but would look at it the next time I bring it in. He told me if it was anything serious, of course the check engine light would come up. I'll take mine in when the area rep is in to look at my paint.
When i start mine on a dreafully cold Michigan morning when it's 10 below, it usually idles around 1500 and slowly comes down to around 900 after a few minutes of warming up. I notice it kinda has a "surge" - although the revs don't change - every 3/4 of a second or so that makes the car shake a tiny bit, but it's barely noticable.
Well, picked up my 6 speed and they did not know why my car was vibrating in idle. They checked the engine mounts and found they were fine, tried adjusting the timing but it didn't help. It's been noted and they will check other 6 speeds to see if they also run a little rough. There were none at the dealer yesterday so they will have to wait until they either get one or if another person takes theirs in. They looked at the CL/TL Type S autos and found that those were rock solid and didn't run rough like my CL.
So I guess I'll have to wait or I'll have to get together with one of the AZ owners to check it out myself.
DerrickW
11-15-2015 05:52 PM
