Rough Idle at stop, Help.
Hey everyone, well i'm having a problem with my 01 cl-s. Whenever i come to a stop, my car would idle rough. It idles at 200-500rpm. It would sometime feels as if it will stall then it would go back to 600-700rpm. Has anyone have this problem? I was thinking it might be something to do with the sensors on the intake. Any help would be thankful. thanks
It is actually not a sensor, but a valve body (Idle Air Control Valve). I just removed the part and cleaned it with intake/carb cleaner. Has been fine ever since.
I remember the most time consuming part being getting to/removal of the throttle body (which still didn't take THAT much time). After that, there are just 2 bolts holding on the IACV.
Make sure you keep track of the gasket between the IACV and its mounting point. Mine fell off without me knowing, which made for some fun troubleshooting as to why the car was running so horribly bad and leaking coolant.
This thread has some pictures of the part itself:
https://acurazine.com/forums/2g-cl-2001-2003-50/replaced-iac-valve-479308/
Ultra Negro
It might not even be that, have you checked the EGR plate on top of the intake manifold?
It might be clogged mine had the same problem you had, but once i cleaned that the idle issue went away.
08_UA7_Gr33k
02-11-2016 02:17 PM
MrHeeltoe
09-28-2015 05:43 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
