Rotors THIRD TIME
Rotors THIRD TIME
Need new rotors for the third time last two sets came from (KVR ) i get about 15000 miles before they shake who do you sugest, web page and phone # THANKS
if the problem is your front rotors, it could be the calipers. as the car ages, they are known to "hang up" and not dis engage when releasing pressure during braking, causing one or both linings to remain in contact with the rotor , causing superheating of the rotor resulting in warpage.
when changing linings, it is essential to repack the caliper slides with SILICONE CALIPER GREASE to propogate lining /rotor running clearances
I need FI
type "brembo acura cl brakes" on ebay..
I saw the full set for $269 slotted and drilled.
I'm sure they are as good as my rotora rotors, maybe even better!
asahrts
09-04-2015 05:55 PM
