Right Headlight Issue
Old May 1, 2004 | 01:43 AM
kevbethune's Avatar
Could this be a sign of a bad headlight, bad battery or bad alternator?
Over the past week, I noticed that my right front headlight doesn't come on every time I turn on the lights (maybe 50/50). If I reflick the light switch, they eventually come on and stay on. It acts sort of like an old flourescent lamp that you have over your kitchen sink. You give it a few tries before it comes on.
Any one else have these symptoms. I want a 2nd opinion before I take it to a dealer.
Old May 1, 2004 | 02:45 AM
corey415's Avatar
it seems as if you have problems with your connections or your HID ballast is faulty. take it to the dealer.
Old May 1, 2004 | 10:54 AM
DarkSithCL's Avatar
Be Strong AND Courageous!
The lights are too expensive to monkey around with and the wiring is a nightmare...dealer it is....
Old May 1, 2004 | 11:18 PM
bzzcls's Avatar
mine is doing the same thing on the left side...i am thinking the dealer may send me away seeing i only have 1,000 miles left on the factory warranty...would this be covered under extended warranty?
Old May 2, 2004 | 06:49 AM
louisn's Avatar
If you're within the warranty period by 1 minute or one mile, the warranty will cover problems with the HID headlights. Take it to the dealer before the warranty period has lapsed-that could be a relatively high priced item.
Old May 5, 2004 | 06:32 AM
louisn's Avatar
Did the dealer cover it under the original warranty?
Old May 5, 2004 | 12:41 PM
gsrblack's Avatar
I had that problem and it was a bad inverter. Take it in...it should be covered under warranty. Be advised though, after I had it replaced, the colors never match. They replaced all the headlights too and couldnt' get the color to match, so I just left it alone. At least the lights work now.
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
