Revisited: Tein SS vs Comptech Springs / Koni's.
i know, i've been trying to search but have come off empty.
during this debate i want to know what you guys think for those that have tried lowered springs and konis vs tein ss.
i understand tein ss allows height adjustability for practically the same price as the the comp's and the koni's,
but which provides the better feel? which lasts longer?
maybe blxmjx could fill in the gap as i haven't had experience with the tein ss's, but have had experience with lowered springs and koni's and they are solid.
sorry for the revisited post, i just want what is best.
have you tried revisiting the search button ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
i will know more this week when my teins arrive.
if the comptechs offer the drop you desire, and you have no need for height adjustability, i'd say stick w/ the springs/koni's.
i need to go lower and be able to raise the car for winter driving, so the teins should work well for me.
the racespring/lowerperch setup is low, but it rides like hell.
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
Originally posted by TLCL
no i tried the search. .seems like its coming up on empty with the very old posts. .not sure why?
The search is useless anymore IMO.
you coulda had a mod change your user name ![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
now you're a supernoOb.
79 posts, down the drain :'(
The Creator
like matt said... if the comptechs are low enough for you... they are the IDEAL setup.
they are one of FEW springs which are PERFECTLY tuned to OUR car.
i've had Comptechs, Ground Control's, and TEINs...
Comptechs are the best feeling spring.
TEINS/Others simply arent made for OUR car... and you can feel it.
soopa, how are you liking the teins?
can you give us a little review?
an adult perspective
but do Comptechs resolve the issue of a lower rearend due to a system install? tried to get this answered in another thread but didn't get much in the way of a response.
i would say yes, since the comptech springs make the car sit with a rake.
with a heavy system it should sit even
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
nope
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
no, are you totally stock, suspension-wise?
yes. haven't done anything to the car outside of the system yet. the (apparent) weight of the subbox is starting to impact the stock setup, exaggerating the 4x look up front. hence my other thread on what to do about the inverse rake, and the best way to correct. was even thinking that the only way to rectify might be to lower the front and leave the rear alone - save sways. thoughts?
If and when Tein makes the mods to the CL bits to allow the stepper motors to fit (summer time frame?), the EDFC will be an option and this is going to be very interesting.
While they don't have variable spring rate that the Praxis and other system (Mercedes) have, the ability to change the rebound and compression damping from inside the car should go along way -- with the right choice of coilover spring -- to make them acceptable for cruddy roads - and twisty hills.
Too bad they don't have the ride height possibilities that the Praxis system does
![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
If you are completely content with your sound system and think you will be sticking with it, you might want to consider changing to another make of spring in the rear. I believe there are some people that are doing this.
Perhaps a: "Are you using different springs in the front and rear" might attract a few responses from some members.
You also might want to check with people that have had the Comptechs on a while and see how the front settles relative to the rear with time...
BMW used to sell three different heights of spring pads as factory options to allow users to adjust the corner heights on their cars (three was all that was available for my car so there may have been more). The rear ride height could be changed upto 1/2" by swapping out one of three spring pads. They had them for a number of cars and some aftermarket folks made them as well.
Wonder if it would hurt to see if some of the pads in the Honda/Acura line up could be used for the same purpose?
Cost Drivers!!!!
So tein is planning something for the CLS?
Do feel free to call them. I suspect the more people that call, the better...
P.S. -- when I asked if they were going to make different stepper motors, they said NO! They told me they were going to modify the current coilovers (and associated bits and pieces) to allow the current stepper motors to fit. When I asked about smaller stepper motors, they said that they weren't sure that they would be strong enough and last long enough.
YMMV
... you might want to consider changing to another make of spring in the rear.
I would recommend the coilovers...especially if your planning to drop a system in the rear or get rims. The price of the Teins (from blxmjx) compared to CT springs and koni, while maybe slightly more expensive, it's definitely worth it. Also if you are performance oriented, Tein has an upgrade option where before you get the coilovers, they will upgrade the springs and revalve the shocks for like another 10-15% stiffness on top of what it is already for $60 per spring...so another $240 to the total purchase price. And yea it sucks that the EDFC does fit the CL, but fits the TL. Hopefully they will have something out soon that will work.
appreciate the info. Would I be wrong in assuming that I would require a camber kit with the Tein's that I wouldn't require if I went the Comptech route, and does Tein offer such a product or would this require a Comptech camber kit? I do already have a system (which is probably the cause of the reverse rake) and rims are a consideration - although I just may go the 235/45/17 on stock rims until I make up my mind (and see how much this is all going to set me back). Don't think I'd be seeking the addit stiffness, as I spend over 2 hours a day commuting in this thing as it is, although it is mainly Interstate surface. tks again.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
