rev matching?
Old Dec 23, 2006 | 02:42 PM
ttomas's Avatar
rev matching?
Hey guys... I have a 2003 cls auto and have a newbie question with the term rev matching. These days I'm seeing cars advertised with rev matching paddle shifters. Is this any different than downshifting in sports mode? Can someone explain the diference if any exists? Thanks... (REALLY regret not getting a 6 speed)
Old Dec 23, 2006 | 04:14 PM
PimpCL23's Avatar
contrarian in fashion
good luck with the tranny!... oh and... i dont kno! lol
Old Dec 23, 2006 | 05:18 PM
fuzzy02CLS's Avatar
It's when the cars ECU raises the rpm's to match the current rpm as you shift. It makes the shift smoother. It's the same principle as with a human doing it with a manual car, but is computer controlled. On the auto CLS there's no such feature.
Old Dec 23, 2006 | 05:48 PM
Jayw/clS03's Avatar
Occasional Browser
I do it the human way... manually. It saves synchros, makes the downshifts smoother
Old Dec 23, 2006 | 07:30 PM
Chopsie's Avatar
Beware of leakage
I do this as well (manual)
Fuzzy answered the question though.
Old Dec 23, 2006 | 11:51 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
It also saves a lot of wear on the clutch. Downshifting wears the hell out of the clutch, even more than the typical upshift. I rev match as much as possible.
Old Dec 25, 2006 | 06:45 PM
Techniques's Avatar
i rev match on my 01 auto in tippi...... is it bad for the tranny?
Old Dec 25, 2006 | 06:50 PM
bigblackjohnson's Avatar
How? Do you pump the gas pedal quickly between the shift to get the revs up between gears?
Old Dec 25, 2006 | 08:20 PM
NightRider's Avatar
SOLD
The auto CLS's (01 at least) have a bit jerky 2-3 shift at low speeds, but I try to rev match then and whenever I can. I just slightly press the accelerator while upshifting in SS mode. It is a bit hard to control exactly though, you have to take into account the gear ratios and pedal sensitivity. Wish I had a manual....
Old Dec 28, 2006 | 12:23 AM
Techniques's Avatar
so is it bad for the tranny? on autos? and to do it. the time when you down shift in tipp. you tap the gas when it is down shifting to the rpm that i will be in the lower gear.
DerrickW
Nov 15, 2015 05:52 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
Brandle34
Sep 23, 2015 07:20 PM
eastcoastguy
Sep 23, 2015 06:29 AM
