Resetting SRS light, help!
Before I begin, yes I have searched and found a couple of things most of them do not all apply to the SRS light. I replaced my battery and the SRS light came on about 100 miles after. If anybody can please just give me a straight answer or DIY on how to reset this light, it would be greatly appreciated, thanks guys.
Missing my Acura's
Check out this thread...
https://acurazine.com/forums/showthread.php?t=179416
Thanks REDLINEN. I just called Acura of tempe and they said that more than likely if you havent had the problem before it's usually not the warranty issue that that thread was talking about. He said it's usually a low voltage issue that makes it go off. Such as when a battery is replaced. I geuss I have to take it in and cough up the $110 to have them fix a stupid light. Thanks again guys.
I'm here in spirit...
I tried but alot of the threads end up talking about something totally different. Also, when somebody tells you how to reset the ecu somebody else chimes in and says to do it a different way. I heard that you can reset everything by disconnecting the negative battery lead and then taking out the fuse for the clock under the hood. correct me if I'm wrong or if this will not work. I would hate to spend all that money at the stealership, when I could be getting my iPOD adapter. Please somebody come forward and let me know the "real deal".
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
