Replaced stock red LED on driver door with ...
Retired. Not available.
super bright blue LED. Even though, it's not as bright as it would be if flushed mount but it's cooler the stock red LED. the process is simple and straight forward. remove the door panel, de-solder the stock LED from the small board and solder the blue LED on.
Ambidextrous Masturbator
Originally posted by SilverKnight:
<STRONG>super bright blue LED. Even though, it's not as bright as it would be if flushed mount but it's cooler the stock red LED. the process is simple and straight forward. remove the door panel, de-solder the stock LED from the small board and solder the blue LED on.</STRONG>
Pics?
my digi went out of battery. besides, it was so hard to catch the blinks with digi.
Yup, I believed NovawhitetypeS was talking about it but he's waiting for me to put it on.
<STRONG>my digi went out of battery. besides, it was so hard to catch the blinks with digi.
Yup, I believed NovawhitetypeS was talking about it but he's waiting for me to put it on. He was thinking about paying $15/each. I paid 2.95+tax. </STRONG>
Originally posted by Chris:
<STRONG>wow you make it seem so simple... but i'm sure many do not have a soldering iron </STRONG>
Soldering irons run about $12 at Radio Shack.
The instruction is really straight forward.
1. Remove door panel. There are 2 screws. One under the arm rest. The other at the door handle. Use a small screw driver to pop the little cover up and the screw is there. You need to remove the tweeter housing as well. Remove the housing by holding the upper right conner and pull it out.
|\ <===Pull out here.
|____\
Pull out the door panel then lift it up from the door edge (bottom of the windows)
2. Disconnect all wiring harnesses.
3. Locate the little board that holds the LED. Unplug the wiring harness. Use a small screw driver to release the tab that locks the board in place. Be careful here, do not break the board. Pull the board out so you have room to work.
4. De-solder the stock LED. Solder the aftermarket LED in.
IMPORTANT: BE CAREFUL about the polarity of the LED. If you install it reversed, it wont work. Make sure you notice the stock LED's polarity before removing it. If you have a volt meter with diode checking capacity, you can always test for polarity. If the aftermarket LED doesnt work after you install it, remove, turn it 180 degree and solder it back in. Even I have de-soldering tool, it still tough for me to take it out (space limited) so try to get it right the first time. Good luck.
|____\
Not Asian
Originally Posted by Shawn S
WOW......This thread is older then DIRT.
Not Asian
Originally Posted by medicshane
what type of bulb and where can i get it
LOOKS GREAT!!!
LOOKS GREAT!!!
https://acurazine.com/forums/showthr...light=door+led
hmm, ok is it is 3mm or 5mm? and whats the consumption, the whole thread doesnt talk about the main thing, the LED itself, lol...give me info guys please...thanx.
tman570
06-11-2019 07:56 AM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
