Replaced the clutch now i have issues.. HELP!!
Old 10-18-2015, 07:25 AM
KingBattle's Avatar
So I replaced the clutch with the LUK about two days ago. A buddy and I did the job but now I have some issues. When I test drove it I noticed that it will not go in 5th or 6th gear. This was not an issue before I took the trans out so I know its something I did while putting this thing back together. I have been reading that you have to bleed the clutch fluid reservoir and that may cause it. I also read that low trans fluid can cause this but that sounds odd.
Second problem is the speed ohmmeter isn't working. I goes up between 20-30 mph and then back to zero but most of the time it just stays at zero.
Other than those two major things it runs good, let me know if you guys have any input. I might look to put it back on the lift tomorrow morning to replace the fluids to see if that helps.
Old 10-18-2015, 11:20 AM
teh CL's Avatar
When you put the shift linkage back on was the car in neutral?
As for the speedometer, did you fuck up the speed sensor on the tranny or maybe its not fully clicked in?
Old 10-18-2015, 01:12 PM
KingBattle's Avatar
Not sure if the car was in neutral or not. Does that make a difference? I hope I don't have to take this thing apart again.
Also I may have messed up the speed sensor. I'm just going to buy a new one and put it on a lift and see if that fixes it.
Old 10-19-2015, 06:34 AM
KingBattle's Avatar
Bump
Old 10-19-2015, 04:55 PM
KingBattle's Avatar
Bump
Anyone knows what this piece is called. The clip was broke off maybe that's my trouble?
Chef Ray
4G TL Problems & Fixes
08-24-2021 08:04 PM
tjwgrr
27
11-24-2015 06:45 PM
jroca
10-22-2015 11:11 AM
brent byers
10-21-2015 10:00 AM
immadorkhead
3G MDX (2014-2020)
10-19-2015 12:17 AM
Quick Reply: Replaced the clutch now i have issues.. HELP!!
