Removing rear seats
Way Fast Whitey
Removing rear seats
How do you get the rear seats out of the car? I am trying to run cabling from the rear storage under the center console and up into the dash.
ex 6 Speed owner :(
Yank hard, straight up on the front of the cushions and they will pop up. Only clips hold those in. The rest of the stuff is held in by a couple bolts you will see when you remove the bottom cushions...
yea, the bottom rear seat cushions just pop up but it takes some muscle. The rear seat backs are held in with bolts and the center console in the rear seat is held in by bolts that you can access after removing the bottom seat cushions.
STYLES B holla at yo BOY
i took my seats out in my cl to put my springs on i had like three or four screws where the back of chair met the seat and it pops out after that might have to put lill muscle in it like uber'cls said
go crazy! at first, i took it slow, and got no where. so i got pissed like the hulk and the bottoms seats popped off! worked like a charm. i jsut have deformed bottom seats now.
yup there are four screws for the back seat, two on the outside of the seat where the seat belts would fall down and two in the middle on the outside of the console. These 4 screws are on the bottom, unscrew them and lift the back seat up. Its a bitch to get out of the car though so have fun with that.
The rear bottom seats just pop up...pull on them from underneath
Spectacular Aroma About
Just be careful not to wrinkle the seat cushions! Especially the front corners. Someone wrote that they would push their knees into the front side of the seats and then pull up...it helps, but my corners were wrinkled.
rockyboy
08-04-2024 10:35 AM
