Removing rear seat
says "hello to my TLX".
you would have to remove the bottom cushions of the seat and center console first. the seats pop off by pulling up. then use a 10mm socket wrench to remove six bolts. two of them on the front part of the console, two in the rear(which are longer bolts since they traverse both the console and seat anchors). and the last two bolts are on either far sides by the seat belt anchor. after you remove all of the bolts, pull the entire rear seat upwards. to install, just reverse the process. when doing so, just remember to slip the pegs of the seats into their anchors/inlet holes(?).
LL
LL
rockyboy
12-06-2022 02:29 PM
