Removing Power Steering.....?????
to see whether or not the power steering is causing the shaking i am feeling. I am tired of taking the car....already changed my motor mounts and front wheel bearings......and I still have the same fucking problem! The only two option left of what can be wrong are the power steering or the front axles. So I want to check if removing power steering will eliminate the problem!
If your steering wheel is shaking when you are driving, you either have an alignment problem, bad tires, bad front rotors, or all three. Try rotating the tires first if the back ones are good. If that doesn't work, go have your rotors replaced by dealer. Finally, if that doesn't work, go have an alignment done. Sears does computerized alignment for $69.00, or take it to the dealer. BTW, the dealer sould cover all of this if you still have the bumber to bumber warranty which is 4yrs/50K, and what kind of dealer have you been taking it to that cant find out what the problem is? Well, I hope this helps a little.
ALL i WANT TO KNOW IS: HOW DO I REMOVED POWER STEERING??
Originally posted by mushutofu
Just take off the belts. That way you can also reengage the power steering if you want.
If your steering wheel is shaking when you are driving, you either have an alignment problem,....
Originally posted by Quick Silver
Is power steering the only thing that runs off of that belt? If I remove the belt, can I still drive the car normally?
Joseph Stansbury
34
12-04-2015 01:57 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
