removing A pillar and side panels without breaking anything
Old 03-18-2009, 04:43 AM
YeuEmMaiMai's Avatar
removing A pillar trim and driver's and passenger's side panel to run Sirius wires. how can I do this without busting anything up?
also how easy is it to fish the satalite ant cable from the sun roof area to the a pillar? I want to stick the magnetic antenna on to the sunroof shade and run the cable down the A-pillar to the receiver dock that I have attached to the tray door
Old 03-18-2009, 05:17 AM
m733l's Avatar
i would try to do the install in warmer weather. it helps to keep the plastic softer and easier to pop off. when i use to install in colder weathers the plastic was a lot more brittle and was prone to snapping. other than that it should be pretty straight forward on removing the a pillar and side panel. not sure where your located but if it is cold just run ur car with the heater at max for 10 min.
Old 03-18-2009, 07:36 PM
any other ideas?
02-25-2020 09:57 AM
CadiGTi
09-14-2015 06:37 PM
PortlandRL
09-14-2015 12:01 PM
04tler
09-10-2015 01:13 PM
Quick Reply: removing A pillar and side panels without breaking anything
