Remote for Doors/Trunk
Old Jan 31, 2010 | 02:09 PM
98JDMCL's Avatar
Justin's
My car didnt come with a remote but i have a extra remote from a 98 acura 3.0CL. Can i get this programmed for my 2001 acura 3.2CL Type S at the dealer? Thanks
Old Jan 31, 2010 | 02:15 PM
Rapture's Avatar
I'd say so, considering you can get most any aftermarket remote programmed for your car.
Unless Honda has some weird design thing with their remotes.
Old Jan 31, 2010 | 02:22 PM
98JDMCL's Avatar
Justin's
Hmmm Perfect! I wish i can do a RL key fob but $$$ its a $400.00 key.
Old Jan 31, 2010 | 03:39 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
ebay
Old Jan 31, 2010 | 08:23 PM
Rajca's Avatar
wham bam thank you ma'am
doubt u can. unless the numbers on teh back are teh same as the numbers that are on the 2nd gen tl.
Old Jan 31, 2010 | 08:54 PM
clpassenubye's Avatar
ABP-KBP-CBP & ME
He's right it won't work I tried that when I had both 1st and 2nd Gen CL's with my extra 1st Gen remote and it didn't work. That being said I have an 2001 CL fob for sale in the Black Market.
Old Feb 1, 2010 | 08:37 AM
Nicks01CL-S's Avatar
"DD" Designated Drinker
Try it. hold the key fob to the lower side of ur steering column and hold the lock button down. put the key in the ignition and turn it to the on all the way position without starting. hold for 30 secs. and it should program. if not then probably wont work
Old Feb 1, 2010 | 09:01 AM
98JDMCL's Avatar
Justin's
is that how you really do it? WOAH! Thanks.
They charge $120.00 to do that at the dealer? LOL jeeez
Old Feb 1, 2010 | 09:09 AM
98JDMCL's Avatar
Justin's
1. Turn the ignition switch on (II on the ignition)
2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine)
3. W/in 1-4sec, turn the ignition switch off
4. W/in 1-4sec, turn the ignition switch on(II)
5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again.
6. W/in 1-4sec, turn the ign. switch off
7. W/in 4sec, turn the ignition switch On(II)
8. w/in 1-4sec, push the transmitter lock or unlock again.
9. w/in 4 sec, turn the ign off
10. w/in 4 sec, turn the ign ON
11. W/in 1-4, push the transmitter again
12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again.
13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and pull out the key.
15. Confirm proper operation with the new codes
Is this the same thing?
Old Feb 1, 2010 | 09:22 AM
yep! the deal likes to make money. Mercedes tried to charge my girlfriends mom 150$ to program her radio and reset all the setting on her CL320.... i was like hold the fuck up! all that info is in ur owners manual. people like to rip people off
Old Feb 1, 2010 | 09:37 AM
98JDMCL's Avatar
Justin's
Nick which one should i do , the one you told me to do for 30 sec's or that whole list of shit?
Old Feb 1, 2010 | 10:19 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You can use the remote if the Frequencies match, some do some don't
Old Feb 1, 2010 | 10:27 AM
98JDMCL's Avatar
Justin's
Can you explain what you mean by that Chris?
Old Feb 1, 2010 | 01:06 PM
civicdrivr's Avatar
Look at the back of the remote. Theres an FCC number on there. You want those numbers to match. Thats how you know its on the same frequency.
Old Feb 1, 2010 | 01:17 PM
try both just print them off. mine worked for my CL/TL FOB but when my friend totaled his RSX i tried to use his but the frequencies are different. aka no trunk pop...... but ya mine was able to work with just the lock button with key on but u will know. if all else fails its probly the FOB
Old Feb 1, 2010 | 01:20 PM
Rajca's Avatar
what we said
Old Feb 1, 2010 | 03:21 PM
98JDMCL's Avatar
Justin's
How do i know what this number is?
Old Feb 1, 2010 | 03:49 PM
Rajca's Avatar
it most likely wont work. seeing how the remote from an 02 accord didnt work with my tl. highly doubt that 1st gen cl remote will work with 2nd gen cl/tl but try it out
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
