relay and switches diagram help needed
hi, here is a diagram I made wonder if anything with expert advice can comment. thanks
How I wired it - explanation:
The 'power inverter' is connected directly to the car battery. The on/off switch of the power inverter is connect to the terminal 87 on the relay. Ignition/ACC is feeding to terminal 86 connected using a 'led switch'.
Terminal 30 should be the car battery but I already have it wired to the power inverter to give it constant. It requires just a flicker of the on/off switch to turn on the inverter on or off.
having two switches there is redundant. i would run it with out the ign switch and only use the switch off the inverter. if you want the switch from the inverter to only work when the ign is on then wire the ign wire to 87 and 86. if not, run 12+ to 86 and 87. that will allow you to turn the inverter on/off as you pls. ground out 85 and run the power wire from the switch of inverter to 30 with a fuse if it doesn't have one already. this way your power invert will only trun on with the ign on.
having two switches there is redundant. i would run it with out the ign switch and only use the switch off the inverter. if you want the switch from the inverter to only work when the ign is on then wire the ign wire to 87 and 86. if not, run 12+ to 86 and 87. that will allow you to turn the inverter on/off as you pls. ground out 85 and run the power wire from the switch of inverter to 30 with a fuse if it doesn't have one already. this way your power invert will only turn with the ign on.
mada51589
05-03-2022 08:54 PM
Soul_Deamon
11-13-2018 04:44 PM
Skirmich
09-15-2015 06:41 PM
