Rear Main Seal
Old Mar 2, 2017 | 10:28 AM
mattcl-s's Avatar
Rear Main Seal
Yup she's leaking good now I have been putting this off for too long and now the time has come. Now I am going to do the clutch too might as well since everything is going to be out what I want to get some answers on is should I go with the Luk Clutch and Flywheel? I saw the prices of xlr8 daily and that would put me wayyyy out of budget. I seen some people say that Luk is what Honda uses for OEM replacements is that true? and is it worth it in terms of reliability can someone clear the air for me I would appreciate it thanks guys
Old Mar 2, 2017 | 10:39 AM
Luk are good OEM replacements
Old Mar 2, 2017 | 11:07 AM
mattcl-s's Avatar
just did a little more research found that Luk is an OEM supplier to Acura/Honda! going to order it off Rockauto for 395 shipped
Old Mar 2, 2017 | 11:15 AM
teh CL's Avatar
OEM ftw
Old Mar 10, 2017 | 10:25 AM
mattcl-s's Avatar
Clutch came in today, will get my car back this afternoon. 700 some $ later will have new clutch, rear main seal, and oil pressure switch
Old Mar 10, 2017 | 11:01 AM
Karanx7's Avatar
Unregistered Member
That's a lot for just the clutch. It's like $180 on Amazon right now.
Unless that's including the fllywheel, in which case that's a great deal. Either way, these LuK (OEM) clutches last a very long time, so it's a good investment for a stock motor.
Old Mar 10, 2017 | 11:05 AM
mattcl-s's Avatar
Flywheel was included
Old Mar 27, 2017 | 09:51 PM
Jamco6000's Avatar
6th Gear
Do you happen to remember if your new flywheel came with the pin installed in the cam side?
https://goo.gl/photos/FXrtgDDne3kxD8wN7
Old Mar 28, 2017 | 09:39 AM
mattcl-s's Avatar
I do not remember. I only took a quick glance at the flywheel just to check for any damage.
