Really odd headlight problem....really odd. help!
Old Oct 22, 2009 | 09:00 PM
evan03CL's Avatar
Wait...I just blacked out
Ok, so some set up. My headlights have been running great. I haven't replaced the HID's, highbeams, nothing. Been running 100% since the day I got the car. No problems until I got into the car today/tonight and turned the headlights on.
Heres what happens:
first click of the lights- side markers/turns come on just fine
second click of the lights- right headlight comes on, left headlight is off and high
beams are on at like 45% power. looks like they are about to burn out
click the high beams on- HID light turns off, and high beams come on full power, left side HID still out
what could the problem be?
Old Oct 23, 2009 | 12:24 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Same thing just happened to me,check my Thred.check fuse box under your hood in the back on the left and see if your headlight fuse is blown. Bet your ballast is bad
Old Oct 23, 2009 | 12:25 AM
dave586270's Avatar
Chamorro
Another user had a similar problem a day ago and it turned out to be a bad ballast causing an electrical problem with all the lights. Seems very similar to his problem. He just bought an aftermarket HID kit and is replacing both ballast/bulbs/etc so he doesn't have to worry about the other ballast. There is a group buy in the BM for kits, like $60. GL!
dave586270's Avatar
Chamorro
Haha, damn, we posted at the same time! Yep, this is the guy!
Old Oct 23, 2009 | 12:26 AM
MrFluffy's Avatar
To many cars in my garage
I had a similiar problem when I got in an accident and mine was a wiring issue (a short circuit).
Im not saying thats what is wrong with yours but it could be
Old Oct 23, 2009 | 01:03 PM
evan03CL's Avatar
Ok so I checked the fuses and the headlight fuse (left) was blown. So I put another one in, blew immediately. Does this mean I have a bad ballast? Is it too expensive to just replace one? What makes them go bad?
Old Oct 23, 2009 | 01:06 PM
I'm leaning to yes ,100%. I changed everything,and had the same results.When I tryied the ballast from the other side,no blown fuse and it lite fine.
civic mentiond something about rain/water to me and mine did not work durring a raining period of the week
Old Oct 23, 2009 | 01:39 PM
gnuts's Avatar
3.5 psi
our ballasts are not sealed like new models, so moisure can get in and fry them. It's probably your ballast. Put some silicone where the wires come out on your new one.
Old Oct 23, 2009 | 07:09 PM
Fito510's Avatar
2003 Acura CL Type-S
its the ballast it happend to me its not a short circuit its best to just get an aftermarket HID Kit ballast because the OE ones are about 300 and aftermarket 60
Old Oct 23, 2009 | 09:27 PM
Rajca's Avatar
wham bam thank you ma'am
black market, ebay, and meets are ur friend.
Old Oct 23, 2009 | 10:57 PM
MrFluffy's Avatar
Its A short circuit in the balast
Old Oct 24, 2009 | 01:14 AM
ChineseGuyinthe415's Avatar
^^^ i was just about to say that you have a short also. Check the wires and make sure they're not frayed or sitting next to something that could ground it.
Sometimes the insulation on the wire looks fine but the wiring inside might be bad. Do a voltage drop test on the battery to ballast
Old Oct 24, 2009 | 08:01 AM
Rajca's Avatar
one of the connectors on my left headlight would get loose somehow and the headlight would turn off. it was driving me crazy. so i plugged the connector in and put a ziptie around it. not the same problem u have but check the wires.
Old Oct 24, 2009 | 06:36 PM
Fito510's Avatar
well the point is that ur gonna have to replace the ballast
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
h22lude
Sep 27, 2015 06:22 PM
mellsonnj
Sep 24, 2015 04:42 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
