Reading light issue
Check passenger #11 fuse.
To replace bulbs us a small screw driver and pry the clear lens off.
At this point you can remove the whole assembly by taking the 4 scews out, 2 under the clear lens and 2 in the glasses holder.
I finally was able to work on this issue, and was surprised at what the issue was. When I took the panel down, found that the 2 'posts' that hold the panel in place when you press the light button broke. So, when you pressed the light button, it just moved the panel up. What I did to fix the issue, I glued the 'posts' in place, then put a rubber washer on top of each one. The washers, when you put the main panel back up, would take up the space between the 'posts' and the roof. By doing this, if the glue didn't hold, the washers would old the panel in place when you press the light buttons. Works great!!
navtool.com
01-22-2016 09:20 AM
navtool.com
11-16-2015 08:28 PM
navtool.com
11-16-2015 08:04 PM
