Reading Check Engine Codes - NO DEALER OR AUTOZONE REQUIRED!
VOTE OUT THE BUSH REGIME
1. Jumper the service connector
2. Turn the ignition key to ON
3. Count the flashes on the instrument panel
4. Look up what the code means
the flashes will be a series of long blinks, a pause, followed by short ones. For example:
Long-Long-Long-Long-Long-Long-Long____ShortShort
7 long and 2 short, indicates a code 72, Cyl #2 misfire.
Once you've got the code, you should have a pretty good idea of exactly what the problem is. You can troubleshoot from there.
![](http://www.honduh.com/diy/checkengine/001.jpg)
![](http://www.honduh.com/diy/checkengine/002.jpg)
![](http://www.honduh.com/diy/checkengine/004.jpg)
![](http://www.honduh.com/diy/checkengine/005.jpg)
after putting my oil pan back on my 98 V6 accord I started it up and the check engine light came on. I used a paper clip and the above method and read a code 65... Secondary O2 sensor. Apparently while moving the exhaust to get to the oil pan I accidently pulled out the connector for the O2 sensor for the catalytic converter.
Reconnected it, reset the ECU and the check engine light went away!!
I didn't even have to leave my garage!!
I found it v6p.net while looking for a way to reset the check engine light.
Even though my asian honda tech would check it out for free I was happy not having to drive anywhere.
I'm sure it will help someone!
i just use this
![](http://www.davisnet.com/productpics/big/8220_Keys.jpg)
plus i can get a bunch of other info out of this thing too like
RPM
Throttle position
Engine load
Fuel pressure
Fuel system status
Short- and long-term-fuel trim
Battery voltage
Timing advance
Coolant temperature
Air flow rate
Intake air temperature
Intake manifold pressure
Oxygen sensor voltage
all for less than 200 bucks
RPM
Throttle position
Engine load
Fuel pressure
Fuel system status
Battery voltage
Timing advance
Coolant temperature
Air flow rate
Originally posted by JakeCL
i just use this
RPM
Throttle position
Engine load
Fuel pressure
Fuel system status
Battery voltage
Timing advance
Coolant temperature
Air flow rate
i just use this
RPM
Throttle position
Engine load
Fuel pressure
Fuel system status
Battery voltage
Timing advance
Coolant temperature
Air flow rate
Originally posted by greenmonster
The good old paperclip and count the flashes works on most OBD cars. Just gotta find the documentation for what the codes mean.
Great Reference
Great Reference
http://www.iequus.com/obd_def.asp
Off to the archives...
