Random Technology Cat... oh no, not again!
Old 11-13-2006, 08:24 PM
CleanCL's Avatar
first: thank you josh @ excelerate , if you buy ANYTHING, make sure you buy from him
second: in my neverending search for perfection and performance, i decided to go ahead with this. quality looks very nice, all welds look solid. this looks much bigger than my car-sound cat, the inlet/outlet diamater is actually SMALLER. this is less than 2" which is roughly the stock size, my currect cat is 2.25. purchased the hardware kit to find gaskets, high quality nuts/bolts, and a warranty card.
Old 11-13-2006, 09:00 PM
big mike 13's Avatar
wheres mine?
Old 11-13-2006, 09:02 PM
CleanCL's Avatar
it's in the mail ;] you should buy one, combined w/ the blower, i'm sure there are some nice gains
Old 11-13-2006, 09:07 PM
Moderator Alumnus
BigLizard's Avatar
I want one!
Old 11-13-2006, 10:24 PM
johntypes's Avatar
I dont want to bust your bubble,but 5 years ago another member and I Bought it from random it is the same as accord 01 promblem was I dynoed 224hp 199.1torque after install dynoed 244 hp 187 torque got to the track and ran 1/3 secound slower that week Spiro and I removed them, torque came back to 199, folowing week want back to track car was the same(may be they improved them good luck)
If you can dyno before and after.
Old 11-13-2006, 10:36 PM
CleanCL's Avatar
i've read both your post and spiro's
but my motor is a little different, i wouldn't recommend this for a regular 3.2 n/a, although i only noticed gains with my car-sound cat.
mclarenf3387's Avatar
He has a 3.5, so torque isn't a huge issue.
What to do, what to think
CL FWD SPEED's Avatar
hmmmm...interesting, time to do some research
Old 11-13-2006, 11:14 PM
JBlueCLS6's Avatar
Don't you have an Auto D=
I joke... But seriously... maybe you need to upgrade that glass tranny to a Dr. Evil or swap a 6
Old 11-13-2006, 11:20 PM
He has a Dr. Evil tranny.
Old 11-13-2006, 11:24 PM
JBlueCLS6's Avatar
Guess I missed that thread D=
I know your NA but what about an Exhaust Dump like Steve had.
Old 11-13-2006, 11:37 PM
Moderator Alumnus
BigLizard's Avatar
I've read those threads as well...but even with my mods, I should be able to get some gains right? I know the premium models exhaust are a little bit more restrictive than the type-S. We'll see...
Old 11-14-2006, 07:23 AM
CleanCL's Avatar
ill sacrifice a few lbs of tq for 20+whp
Old 11-14-2006, 12:38 PM
ghost_masterCL's Avatar
seems strange to gain power from a smaller inlet/outlet cat, though if it still flows better than you're current cat, then I guess it would. be sure to post your final dyno when youg et everything installed and tuned.
Old 11-14-2006, 01:59 PM
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,151 Likes on 1,097 Posts
I've had both Random Tech and Thermal Reserach & Dev hi-flow cats on my previous cars and saw no gains with the G-Tech and felt none on the butt dyno, but that's just my
Old 11-14-2006, 02:15 PM
I'm a Vagiterian.
All Mine's Avatar
Were you just bored with your car sound cat?
Old 11-14-2006, 02:27 PM
CleanCL's Avatar
oh, i forgot to mention. right now know im throw a P0420 which is catalytic converter ineffeciency. so i'm trying to find something that will run fine.
Old 11-14-2006, 02:34 PM
I'm a Vagiterian.
All Mine's Avatar
Ah, that makes a lot more sense. But you are known to buy other shit for weird reasons. lol.
CleanCL's Avatar
who me? like what?
Old 11-14-2006, 02:35 PM
Moderator Alumnus
BigLizard's Avatar
It's better than spending over a $1000 for an OEM cat right?
Old 11-15-2006, 01:03 PM
I'm a Vagiterian.
All Mine's Avatar
who me? like what?
Remember this?
I'm not dissing you. Just playin' around.
Old 11-15-2006, 02:18 PM
CleanCL's Avatar
Originally Posted by All Mine
Remember this?
haha. that was just a lead in for something else, i had planned to get some custom pulleys made, but it never went through / too expensive at the moment.
btw - i installed the random cat today, i took lots of pictures, and the install wasn't 'exactly' bolt on, but it wasn't too bad. so far i feel like the power band is smooth, i didnt see any noticeable loss in torque, only gains so far.
Old 11-15-2006, 02:25 PM
Former Sponsor
Excelerate's Avatar
Hey just a side note. It is a bolt on for the CL-P, TL-P but it is slightly different for the Type S models since the Type S cat has a mid bed 02 sensor and the exhaust flange is slightly larger. I'm sure CleanCL will explain more but I just wanted ppl to know that it is a bolt on for the premium/base model and requires slight modification for the Type S.
Old 11-15-2006, 02:52 PM
CleanCL's Avatar
right. pictures and full explanation coming. i believe this would fit the type s stock exhaust no problem. i think it's the aftermarket catbacks that pose the issue.
Old 11-15-2006, 02:55 PM
Moderator Alumnus
BigLizard's Avatar
So the premium model would definately see some gains over this then...
Old 11-15-2006, 02:59 PM
Former Sponsor
Excelerate's Avatar
I have no dynos but I would assume so. CleanCL had a Car sound cat before this and he said that he feels gains with this cat over the previous high flow cat he had. I would assume you would see a 7-10whp gain with this cat based on what I've read and a few dynos a while back.
Old 11-15-2006, 03:35 PM
CleanCL's Avatar
issue #1: the rear flange on the random tech cat was a bit too small to connect to my comptech b-pipe flange. i solved this by using a unibit and drill into the comptech flange to the 5/8th mark from the cat side since there was nothing in the way. fairly easy to do.
issue #2: the oxygen sensor wire needs to be extended. i purchased a new o2 sensor, so when i took the old one out i just used the extra wiring from the old one, and installed almost the full length using butt connectors (red ones). you can see in my pictures if you follow the wire, you will see it turns into electrical tape. i double taped it. i moved the plastic clip to the rear, and zip tied the wire to the original location.
end result. no CEL.
while the car was up i decided to coat the rest of my catback with high temp black paint good up to 1200 degrees.
my rear
Old 11-15-2006, 04:45 PM
Don't Mess With Texas
cltypeSLOW's Avatar
phat ass.
Old 11-15-2006, 04:53 PM
how handsome I am
agranado's Avatar
I thought of you first the minute excelerate posted the -P's would see gains with this...
Old 11-15-2006, 06:17 PM
CleanCL's Avatar
i'm pretty sure this same cat will fit 98-02 accords, and also the v6 1st gen CL. i may be wrong.
Old 11-15-2006, 08:26 PM
withoutcomp1's Avatar
If i were you i would get rid of those butt connectors from there and solder it, other wise it will get moisture in connectors and corrode the wire. It doesn't matter how much tape you put it will get in there, trust me.
Old 11-15-2006, 08:41 PM
CleanCL's Avatar
i'm going to redo it with heat shrink tubing eventually. i was told NOT to solder these wires due to the fact they work off resistance and solder will mess with that somehow.
Old 11-15-2006, 08:59 PM
johntypes's Avatar
Clean Cl will fit 98-02
Old 11-15-2006, 09:00 PM
I would still try to solder it and see what happens all your going to do is get a cel. Those wires will corrode under there being exposed to all that water.
Old 11-15-2006, 09:08 PM
CleanCL's Avatar
cool. thanks for the advice.
Old 11-16-2006, 12:52 AM
Moderator Alumnus
BigLizard's Avatar
I'm sure you weren't the only one...hehee...
The original title under my name was "Project CL-P"
It'll go back once the car is fixed.
EDIT: CleanCL - I have 1200 degree red paint...I was thinking of doing the same when I put my car up after it's fixed. BTW your rear end looks bad ass. I love the exhaust.
Old 11-16-2006, 12:57 AM
Moderator Alumnus
BigLizard's Avatar
That's not bad at all. I'm going to bolt on as much as I can before I get to work on the internals.
She's got big plans.
Old 11-16-2006, 08:02 AM
RaviNJCLs's Avatar
You planning on dynoing anytime soon?
Old 11-16-2006, 09:42 AM
CleanCL's Avatar
hopefully this month or next.
Old 11-16-2006, 09:54 AM
RaviNJCLs's Avatar
Sweet. Did you have it done before?
Quick Reply: Random Technology Cat... oh no, not again!
