quick wheel question
Old Jun 27, 2002 | 01:08 PM
jimcol711's Avatar
ive got comptech springs, im curious what offset will be ok with 17" and 18" rims....is 40 ok?? or does it have to be higher???
Old Jun 27, 2002 | 01:17 PM
jimcol711's Avatar
our stock rims are +55???? sheeesh,
Old Jun 27, 2002 | 01:24 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
I think you need at least a +42 offset to be safe....but then no 235s if you get such a low offset for the CL.
Old Jun 27, 2002 | 01:26 PM
jimcol711's Avatar
what the min. offset to be able to get the 235?????? i want 235 also, what about bolt pattern?? our car stock is 114.3....its 114 ok??
Old Jun 27, 2002 | 01:28 PM
I think when they list 114....they mean 114.3, that is a standard. I think you might wanna look into something with a +45 mm offset to fit 235/40/18s....and for 19s...i wouldn't try it with anything less than +50 offset
Old Jun 27, 2002 | 03:02 PM
FDao's Avatar
45mm offset, you could probably get away with with the current set up that you have. I have 48mm offset with the 235's and no rubbing thus far.
Old Jun 27, 2002 | 07:24 PM
oce01acura32cl's Avatar
i still dont understand offset. will someone explain it in dummie mode, not all technical n shit
Old Jun 27, 2002 | 09:09 PM
Red Rider's Avatar
Subie Dubie
I've got 225-40-18s 0n 7.5 in. rims with Comptech springs and 48 offset and zero problems, perfect.
booma1218
May 3, 2016 07:39 AM
lland
Oct 4, 2015 04:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
bailey24
Aug 31, 2015 05:38 PM
