quick sway question...
Old Nov 23, 2003 | 04:53 PM
YuppieCL's Avatar
Moderator Alumnus
got em installed finally... night a freaking day difference in terms of body roll and handling... i CANNOT believe i waited 3 years to get sways...
anyway... i bought em used. my buddy who sold them to me put em on...
whenever i go over larger bumps in the road i hear a loose clank coming from the front, kinda under the passengers foot well....
whats up w that? what could it be? what should i do? should i be worried?
thanks
Old Nov 23, 2003 | 06:20 PM
Aegean_Blue6's Avatar
Daily Driver
Maybe double check your end link bolt tighness for the front passenger side? There's specs around for the torque to use on each of the bolts.
Old Nov 23, 2003 | 08:17 PM
linto's Avatar
I had the same problem with my sways. The problem is that you have some slop from the original sways. Once you throw in a bar that is stiffer, it wiggles itself loose. Check the torque on the ball link bolts (indented hex) for the control arms first, then check the torque on the bolts for the sway bar connect. The same thing happend to me where the bolt (or hole if you will) in the control arm already has slop from the OEM bars, and if you throw in a stiffer bar, your off torque will be less.
Sorry if this is confusing. Bottom line, check the torque for 28 ft-lbf.
Old Nov 23, 2003 | 09:09 PM
YuppieCL's Avatar
Moderator Alumnus
WHA?! wow.... please simplify! i'm a little slow.
Old Nov 23, 2003 | 09:14 PM
darrinb's Avatar
///M POWER
i drove a tl-s w/ sways(mod addicts), felt so good, i'm def gonna get em one day
Old Nov 23, 2003 | 11:49 PM
Pure Adrenaline's Avatar
Dragging knees in
Darrin --
You still don't have sway bars!? Come on, buddy.
KBTypeS
25
Oct 1, 2015 04:49 PM
steve
Sep 30, 2015 09:23 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
