Quick question: Where do I jack car from with floor jack?
Old 06-01-2008, 02:53 PM
02CL-TypeS's Avatar
I'm trying to jack the car and check some stuff out. Where the hell do I jack the rear of the car from with a 3-ton floor jack? Any pics?
Old 06-01-2008, 02:57 PM
Uses turn signals in my
TCM 01 CL-S's Avatar
Use the tow hook in the back under the trunk area, it should be very easy to spot. That is how the service manual suggests it. Don't forget to use jackstands after you have jacked up your CL!
Old 06-01-2008, 02:59 PM
6speed
jl03CLS's Avatar
https://acurazine.com/forums/showthread.php?t=193973
Old 06-01-2008, 05:24 PM
failhard.
mystikk's Avatar
If it's attached to the carriage carrying the spare tire, I've jacked up on that once .. and it ended up denting the carriage upwards, making my spare tire pop up from the trunk floor .. wasn't a pretty sight.
Old 06-01-2008, 10:51 PM
that isn't good, is there a chance you jacked up on the wrong spot? I haven't had a problem jacking it up from the rear tow hook before, thats how I did it when I did my RSB with my friend on saturday. The spare tire didn't budge at all. I doubt the service manual would recommend that if it was going to damage the vehicle.
Old 06-01-2008, 11:17 PM
02CL-TypeS's Avatar
I figured thats where to jack it up at., but didn't see anything mentioning that in the service manual...what page?
I tried doin that with my maxima and dented the spare tire area too
Old 06-01-2008, 11:25 PM
'03 ABP YA4-S 6MT
rp_guy's Avatar
should be fairly early in the service manual.. haha
but yeah, you can use the frame rails, but i bent my friends rails on his civic (not the actual frame, but the metal flaps that you would use for the scissor jack). i find that the front and rear jacking points don't raise the car enough to fit stands underneath. so i just jack the frame or any suspension pieces now.
Old 06-01-2008, 11:48 PM
02CL-TypeS's Avatar
the front goes as high as my 3 ton craftsman jack will allow...high enough for three notches on the jack stands(which is plenty). I'm just skeptical on using the tow hitch
Old 06-02-2008, 12:23 AM
Page 1-11, right hand side. FYI for those reading, the service manual is different from owners manual.
Old 06-02-2008, 09:12 AM
failhard.
mystikk's Avatar
I could take a pic, but it should be fairly obvious where the tow hook is, even for a mechanical nimrod like I.
In the end, I had to jump on it like a mad monkey to get the spare tire well to settle down.
Old 06-02-2008, 11:51 AM
ljmushock's Avatar
You should jack each side of the car up independently by the jack point in front of the rear tire. Then put a jack stand underneath one side... repeat the process on the other side. I wouldnt trust the car to balance on that little tow hook
Old 06-02-2008, 03:00 PM
Have you actually tried that on the CL? On a mustang, no problem, on the CL, it requires a dangerous juggling act.
Old 06-02-2008, 03:07 PM
peti1212
ILX
22
01-05-2022 05:14 PM
divac
08-29-2018 10:13 AM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
lland
10-04-2015 04:47 PM
kuzdu
09-10-2015 08:42 PM
Quick Reply: Quick question: Where do I jack car from with floor jack?
